Hi guys, is there a trick to getting a factory centre cap of fuchs to fit into euromeisters? seems a tad too tight??
82 SC Targa Guards Red = Toy 04 E55 AMG Brilliant Silver = DD 04 Cayenne Turbo Platinum Grey on 22s = Previous DD 80 Wide body 12AT RX7 Black 350+ hp= Previous Toy 78 Alfa Romeo GTV Blue = My 1st Cool Car |
Rubber mallet... I bought a set in 2012 and all went on easily. Had to get a replacement wheel (due to impossible to fix balance issue) and had to be very persuasive with a rubber mallet to get it on. I think my cap may no longer fit in a regular Fuchs now...
'88 911 Targa |
cool, i was worried about bashing it too hard...
I have the Euromeister wheels also . I just bought them and ordered a set of original caps from a fellow pelican. They whent on with a tap of a rubber mallet.
(man/dude)
I thought the same with mine - got new Porsche caps and they fit tight, but not impossible. Make sure the cap is "started" before you whack it too hard and it'll pop right in. If the center cap catches on the wheel it doesn't matter how hard you hit it, it won't go. Just a matter of having it set in the right position.
Bringing this thread back to life...no matter what I do I cant get factory Fuchs center caps on Euros. I've spent the last two hours attempting to get just ONE on a wheel with negative results. I'm about to get a Dremmel Tool out. The hole in the Euros is just way too tight.
2018 991.2 Cup Car 2014 997 GT3-R 2010 997.2 Cup Car 1989 911 3.2 Coupe |
My factory caps in black from Pelican went on without a problem.
That's what Ive read and heard as well. My caps are OEM from another set of Fuchs btw....so frustrating.
Member 911 Anonymous
They will loosen over time when you balance the wheels. So keep an eye on them and re-tweek to get a tighter fit.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
For giggles, I tried another set of OEM Fuchs caps on the Euros....same problem. There is a full 1mm+ of material preventing the caps from even getting "started" on these wheels.
, Let's get some measurements to make sure.I have factory caps on my 17" Euros, in the beginning they were tight, now I can remove and install by hand
I wish I had a mic to get an ID measurement...but I don't.
I will tell you that one wheel accepted all 4 OEM caps with the expected effort (and that was not easy)...the other three wheels are WAY off the mark in accepting these caps. Clearly some variances in manufacturing...or a heavy coat of paint in there.
Got them on...Dremel. But they are probably never coming off. Ever.
Ditto. Rubber mallet - hard! But no going back to regular Fuchs I fear.
'88 911 Targa |
