31mm Charlie Bar - Do I Need This Part?
Hi,
Hoping for some help. I have these very big rear sway bars (31mm), that are missing the "donuts". If I need these parts, where could I get a pair of them? Thanks for nay help.
RETIRED
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Thanks Joe Bob, I will contact them.
I have not called ER yet, but I do see them on EBay. They are called shaft collars. I am not sure of the quality of them.
You can buy them at mcmastercarr, they are called split shaft collars
Diss Member
They are very lightly loaded so a cheap alternative like McMaster-Carr is fine. All they do is keep the bar from shifting sideways. You want 2 piece shaft collars made from aluminum. 31mm is an odd size so 1-1/4" will probably do (30 thou difference). Depending on the clearances you might need to shave the flat with a file or use some thin sheet metal to shim it.
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
Thanks for the replies. I have just ordered two aluminum clamp style split shaft collars. Hopefully they will fit, as I ordered 1.25 inch in size.
I am guessing that these sway bars are from Smart Racing, as the outside diameter is the same for front and back - I am not certain? Thanks again. |
