1968 window frame in a 71
Hi, is it possible to put a 68 window frame with the wing window in a 71 door?
yes, easy to do except for finding good 1968 window frames with good chrome on the vent windows. There will be a little mod work to allow the lower pivot shaft of the vent window pass into the door skin, not sure if the later skins are made to accept that.
Paul Abbott Weber service specialist www.PerformanceOriented.com |
Thank you Paul!
Yes and they are two model early is chrome and late one are alu .Late one are the best for swap 69 and up.
