-   -   Question while rebuilding my suspension... (http://forums.pelicanparts.com/porsche-911-technical-forum/935874-question-while-rebuilding-my-suspension.html)
sempaipaul 11-15-2016 07:30 PM
Guys,
I am currently going through a full suspension rebuild and - have the following question I would be very thankful for some opinions on:
I plan on powder coating most of the parts. The question comes on the front/rear hubs AND the rear control arms. Has anyone actually gotten these components powder coated? or, do most individuals simply sand-blast them and call it a day? My current parts are very dirty... as can be imagined by looking at the front hubs alone:
https://s16.postimg.org/pz18lt2ut/hub.jpg
Those of you that have rebuilt your suspensions --- how did you go about this?
Thanks,
Paul
Techno Duck 11-16-2016 09:15 AM
Personally i would bring the parts to a machine shop and have them hot tank it or see if any places near you can perform dry ice blasting. The hubs i would not powder coat either, mainly because i used to regularly inspect the hubs on my track car for cracks. Not saying this will be a problem on a street driven 911, but just old habits for me.
Jdub 11-16-2016 09:59 AM
For sure clean them up as much as you can as nothing goes into a shop's tank that is not free of dirt, plus shows respect for the process. These clean up very nicely and you will be both surprised and glad you left them in natural finish.
If you elect to coat them, you will need to remove any material on the flats that mate to the rotor.
Luccia at Pelican Parts 11-16-2016 10:30 AM
Check out this thread here: http://forums.pelicanparts.com/porsche-911-technical-forum/685339-plate-paint-powdercoat-major-suspension-components.html. There are a few posts in here about powder coating as well: http://forums.pelicanparts.com/porsche-911-technical-forum/712787-best-suspension-part-refinish.html. While you're going through the suspension don't forget to take a peak out our suspension tech artilces here: Porsche 911 (1965-1989) Technical Articles - Pelican Parts.
RSTarga 11-16-2016 01:00 PM
I powder coated my rear control arms, less maintenance. I would not bother with the hubs.
OffCamber00 11-16-2016 01:36 PM
JDub nailed it. The hubs aren't worth coating because the front and back surfaces will need to be carefully masked as well as the inside where the bearings go. Plus, unless you do black they will be coated in brake dust pretty quickly. Plus Plus, you don't see them behind your wheels anyway :)
