Is there two fuel pump relays 1979 911?
I'm asking for my cousin who owns the car, found one under the front hood but was wondering if there's a second relay. The reason I ask is he has a no start, I hear/feel a slight click from the one under the front hood but the fuel pump doesn't make any noise. I hot wired the fuel pump and I can hear the fuel pump, disconnect the hot wire and nothing. Thanks.
Old 10-10-2016, 05:27 PM
Insert Tag Line HERE.....
rattlsnak's Avatar
No, just one relay. Are you checking with just key on, or when cranking engine?
Marc
Old 10-10-2016, 06:20 PM
Sboxin's Avatar
DME relay under the driver's seat - - NOT - - . . . perhaps . . . JMHO of course . . .
Edit: Ooops . . . get our car confused because several different years of stuff . . .
Regards,
2002 Porsche Boxster S Cobalt Blue/Blk/Blk
Crew Chief for Son's 1978 Porsche 911SC Original Porsche Mocha Brown 3.8L NASA race car
Previous Porsches: 1958 356 Red Coupe - 1972 914 Blue -1972 911T Coupe Aubergine
Old 10-10-2016, 06:26 PM
rattlsnak's Avatar
^^ SC's don't have DME relays..
Marc
Old 10-10-2016, 06:29 PM
Just with the key in the on position, thanks.
Old 10-10-2016, 07:01 PM
Test the FP socket and relay........
Remove the FP relay and bench test it. Test also the FP relay socket for any electrical anomaly. Search for DKLever48's thread about FP relay testing. Everything you need to know about FP relay test were discussed in that thread.
Tony
Old 10-10-2016, 08:54 PM
If you remove the relay and jump terminal 30 and 87a that will turn on the pump if the pump is good.
Bruce
Old 10-11-2016, 02:52 AM
Cut-off relay by the left hood hinge. Unplug it.
206 637 4071
Old 10-11-2016, 03:54 AM
rattlsnak's Avatar
Pump will not normally run with key on only unless you are cranking engine (or its running).
Marc
Old 10-11-2016, 08:10 AM
Tony
Going back Thursday to check it out.
Bruce
I thought I read to use pin 87 and 30, can you use pin 87A instead of 87?
Are you referring to the red fuel pump relay?
When you first turn the key to the on position you should hear the pump priming the fuel system, am I correct in my thinking?
Thanks for all the help.
Old 10-11-2016, 08:51 AM
Cut-off relay cuts off fuel pump function on over-rev on early SCs. Find the left hood hinge pivot point and unplug the white plug at the bottom of the square black relay and see if that helps.
206 637 4071
Old 10-11-2016, 11:51 AM
Thank you.
Old 10-11-2016, 02:39 PM
We accomplished nothing today. Removed the fuel pump relay and jumped 30, 87a, I heard a click or something for a split second when the was key turned on ( not to the start position ), yesterday when I ran a wire from the positive side of the battery to the positive side of the fuel pump I could hear the fuel pump until I disconnected the hot wire.
I tried to find the cut-off relay but couldn't, we'll try again Sunday to see if we can't find the problem....just about ready to throw in the towel.
Old 10-13-2016, 01:54 PM
pors1968's Avatar
Did you check if you with test light if fuse is ok and voltage pin 30 .
Old 10-13-2016, 02:21 PM
Checked number 6 fuse ( fuel pump fuse ) and test light showed it was o.k, didn't check voltage in pin 30.....should it show 12 volts? Thanks
Old 10-13-2016, 02:34 PM
pors1968's Avatar
Try to clean wire on both side of fuse .Fuse might be ok but these wire get hot and contact are not good enought.
Old 10-13-2016, 02:46 PM
Basic knowledge......
Dark Age,
Did you get a chance to read DKLever48's post about FP relations test? That is the basic test you need to understand how and what to expect. Otherwise, you will be wasting your time looking for something you have no clue. It would take a few minutes of reading to guide what and where to do the tests. Keep us posted.
Tony
Old 10-13-2016, 02:51 PM
ROW '78 911 Targa
timmy2's Avatar
Did you try the really simple test of turning ignition to run and lifting the air metering plate in the airbox to see if the pump runs? Injectors will squeal if it does, and you should stop when you hear them do that.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 10-13-2016, 03:41 PM
Dark Age,
Tony
I need to re-read it again, one thing in the thread said when he hot wired to the fuel pump the car would run. In our case I could hear the pump but the car wouldn't start, we sprayed some starting fluid and it started and it started but stopped once the starting fluid ran out......also, the starter seemed to stay engaged.
Yes, nothing happened.
Old 10-14-2016, 03:14 AM
DKLever48's thread...........
Dark Age,
You are totally missing the point of my suggestion about DKLever48's post. The objective of reading the post is for you to understand how each terminals are tested. And relate them to your case. So far, I think you are still not aware which terminals are NC (normally closed) and NO (normally open) for the FP relay. It may sound complicated but they are not. It would need less than a minute to evaluate or test the FP relay socket and another minute to test the FP relay.
If the FP relay and socket passed the tests, then you could move on and look for other possible culprits. At this stage, focus on the FP relay/socket/wiring and share your results. Do you understand how terminals 87a, 87, 86, 85, and 30 work with the ignition switch @ ON/OFF positions? If you do, that is great. If you don't, that is another problem for your troubleshooting. Keep us posted. Thanks.
Tony
Old 10-14-2016, 05:36 AM
