-   -   Making a carbon fiber airbox - input appreciated (http://forums.pelicanparts.com/porsche-911-technical-forum/936512-making-carbon-fiber-airbox-input-appreciated.html)
JohnJL 11-21-2016 09:59 AM
Hi all,
As I test fit the engine in the latest Gretchen I began measuring and planning for the air filter assembly. This car has an aluminum Carrera intake, and from a rough placement in the engine compartment I have about 6" clearance from the throttlebody to the firewall.
I had used a giant oval-cone K&N filter with one of their 90 degree elbows on this motor in another car in the past and it would fit this car too but 1. it looks ghetto (my diagonal cut to fit the throttle body wasnt clean, 2. it is a heavy mother and 3. it indiscriminately takes air in from throughout the engine bay.
So in the spirit of competely skunkworking this thing, I came up with a plan...my priorities were to address those 3 things above. I have done enough fiberglass work to know I dont have the skills to turn out a piece that would be acceptable to me. So I concocted an approach to use some pre-fabbed carbonfiber pieces and plates to make something.
I drew up plans for and order some pieces. Sorry, I am travelling now and dont have the drawings with me but it is basically a 90 degree 3.5" elbow from the throttlebody to an airbox located over the 4-5-6 cylinder bank mounted on the stock intake bolts. The elbow enters the airbox on the driver's side. The box will measure 5.5" tall x 12" wide by 12" deep. The box has 5 closed sides and its open end facing the rear of the car. A rectangular filter will fit into the open end supported by a 1" CF flange around the perimeter made from the 90* CF angle. Then a lid also with a CF angle flange sandwiches the filter in place, and forms a mouth aimed at a 45* angle right into the decklid grill. I know, a picture is much more helpful...
Here is my list of materials:
90* elbow from carrera throttlebody to airbox:
CF Elbow
http://www.intakehoses.com/mm5/graph...CF90-350X6.jpg
CF plate forming the box and filter mouth:
solid CF prepreg plate 1/16"
CF 90* angle reinforcement for corners and filter flanges:
CF angles for corners and flanges
https://dragonplate.com/images/photo...-angle-sml.jpg
Filter:
Rectangular K&N filter
https://static.summitracing.com/glob....jpg?rep=False
I havent worked with CF before. I found this video helpful in building confidence...lets see if that is misguided...
https://www.youtube.com/watch?v=EWzN6GZeEzs&t=35s
Easy Composites Video
<iframe width="560" height="315" src="https://www.youtube.com/embed/EWzN6GZeEzs" frameborder="0" allowfullscreen></iframe>
I have a bunch of Hysol products on hand for the actual bonding. Initial research incdicated the e120 was the go?
I am interested in input from others about the approach, methods, tips and tricks...
Dmitry at Pelican Parts 11-21-2016 01:02 PM
Hi John - sounds like an awesome project. If you end up documenting it in detail, check out this link as you may be interested in becoming one of our DIY Project Experts.
I've also found the below link to give you some ideas/troubleshoot the install that you're going to be doing. Hope it helps and best of luck!
C2/C4 Airbox Modification / Upgrade
-Dmitry
Fly911 11-21-2016 04:14 PM
I would like to have a MFI style airbox set up for my Jenvey ITB's. The Jenveys have straight manifolds, and the spacing between each TB is bigger than the MFI/Weber/PMO type set ups. I was thinking of buying an original MFI airbox, cut and space it out to make it fit, and then make molds out of FG. And then make new ones in CF or FG... Have anyone tried this?
JohnJL 11-21-2016 06:00 PM
Originally Posted by Dmitry at Pelican Parts (Post 9367354)
Hi Dmitry,
Thanks, I did that to a 993 I owned years ago.
dsfnctn 11-21-2016 06:48 PM
This was a project of mine. i started off building boats at an early age.
http://forums.pelicanparts.com/uploa...1479782926.jpg
JohnJL 11-21-2016 07:06 PM
That is so cool. You have skills I will never have. Great job!
Rawknees'Turbo 11-21-2016 07:13 PM
Originally Posted by JohnJL (Post 9367889)
That is so cool. . . . Great job!
Agreed - absolutely love it!
Dmitry at Pelican Parts 11-22-2016 01:17 PM
+1 looks absolutely incredible.
-Dmitry
JohnJL 11-23-2016 05:05 AM
What size is that filter? K&N site calculates needing 65 sq in in filter area, yours looks smaller than that? The one I selected above is also slightly smaller, I may return for a Miata filter which is 6.5x12. Same sq in as used in a new AMG C63 so I cant imagine it would choke a 250hp 3.0.
911pcars 11-23-2016 11:22 AM
Kudos for the CF effect/build. However, inlet air temps are pretty much ambient in the engine compartment at speed. Use a paper filter. It's cheaper..... and better.
Sherwood
dsfnctn 11-23-2016 11:17 PM
K&N makes more promises than president campaign speech
JohnJL 11-24-2016 02:55 AM
Yeah, but I see you used one too! What size is it?
The filter will be partially visible with the trunk open, at least the K&N looks OK and does a decent enough job filtering. The paper ones look like crap as they yellow/grey almost immediately.
dsfnctn 11-24-2016 10:08 AM
robust filter sized to fit my project
http://forums.pelicanparts.com/uploa...1480010905.jpg
http://forums.pelicanparts.com/uploa...1480010925.jpg
GaryR 11-24-2016 10:23 AM
After seeing what passes through a K&N filter I would NEVER use one on my car... Stock paper element works just fine.
dsfnctn 11-24-2016 10:25 AM
Lo0ks like you have lots of other work on car. why not something like this
AireTEK Fresh Air Induction Kit-HighFlow, 911, 1984-89
Porsche 911 (1974-1989) - Intake System - Page 2
dsfnctn 11-24-2016 10:28 AM
Welcome to Rothsport Racing - Engine Products
K&N
JohnJL 11-24-2016 11:49 AM
The first one doesnt look like it will clear the firewall with an alu intake and stock throttlebody. Second not sure either will fit the 90mm tb? Both still leave a bit of a .... how do I say this...not the aesthetic I am hoping for.
JohnJL 11-24-2016 11:52 AM
Originally Posted by dsfnctn (Post 9371023)
Thats for the later 964 intake I believe. The twin-chamber like yours. Mine is the simple 86-88 single-chamber alu intake.
Rawknees'Turbo 11-24-2016 01:56 PM
I've been using them for 30 years on every machine I own (bikes, cars, diesel truck, race and public roads) and have never had a problem with dirt getting past them.
robcf 11-26-2016 12:18 AM
Would you mind sharing how you made the manifold?
Did you make a female mold or a core to lay up the carbon?
How did you manage the seams, lap joints?
Thanks,
Looking forward to your feedback.
