'84 3.2 with SSI
When SSI's are installed on a 3.2 with a Motronic system, what happens with the O2 sensor?
I'm in the market for a muffler and cat bypass for my '84 but thought I'd wait until I have some funds for SSI' s as well.
Old 07-22-2017, 07:17 PM
SSI's are available with O2 sensor bungs (or you can add them to SSI's without the bung).
Old 07-22-2017, 07:25 PM
So, it only reads one bank?
Old 07-22-2017, 07:29 PM
Caveman Hammer Mechanic
ClickClickBoom's Avatar
1984 Carrera El Chupacabra
1974 Toyota FJ40 Turbo Diesel
"Easy, easy, this car is just the right amount of chitty"
"America is all about speed. Hot,nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old 07-22-2017, 10:27 PM
I wonder what he uses for reference to maintain air fuel ratio.
Old 07-23-2017, 03:53 AM
Yes, you can run with an O2 sensor reading just one bank, or you can run with it disconnected. If not connected, always open loop, the ECU applies predesignated fuel instructions, just as it does in other open loop conditions, even with O2 sensor connected. Typically it will run a little richer. Maybe better too.
Good luck,
Dave
Dave McKenzie
1984 Carrera 3.2
1984 928S Automatic
2001 996TT
Old 07-23-2017, 05:43 AM
Consensus seems to be that ssi headers are undersized for a 3.2 and don't really provide improvement over the stock exhaust with a cat bypass/premuffler. SSIs will also require some fiddling to adapt to the carrier's heater system.
Old 07-23-2017, 06:19 AM
I'm on the fence about the SSI's. Reasons to do it would be that my HE's are +30 yrs old, weight savings and sound. I'm not 100% sure they're worth it
Old 07-23-2017, 07:13 AM
SSI's are about $1500. You will need a new muffler, and for heat, you will need some additional parts. Search heat backdate. The SSI's are a 1972 replica, roughly. They do sound louder and more robust in general. They eliminate the cat, and may cause emission test problems. I have them. If I had good stock components, I would keep them and replace bad with good salvage off ebay.
Good luck,
Dave
Dave McKenzie
1984 Carrera 3.2
1984 928S Automatic
2001 996TT
Old 07-23-2017, 08:12 AM
