-   -   Dash lighting - not instruments (http://forums.pelicanparts.com/porsche-911-technical-forum/936588-dash-lighting-not-instruments.html)
Tori 11-21-2016 07:54 PM
As a newb, i'm not quite certain what is supposed to be illuminated on the dash....
At night i see the Defrost symbol it lit on the right side of the heater/vent controls, but the left side seems dark. I assume there is a bulb out.
What all is supposed to be lit ?
RSBob 11-21-2016 08:27 PM
Everything on the left of the wheel is dark. On the right rear window defrost and both sides of the air control levers box should be illuminated, but good luck getting your hands back there. Otherwise everything is pretty dark. Using a small screw driver you can pry off. The faces of the knobs and take a look for yourself.
gazzerr 11-21-2016 09:04 PM
You can replace the bulbs by laying on your back in the drivers footwell and pulling the bulb holders out from behind. It's a bit of a PITA but doable. I found mine were in pretty rough shape. I had to re-solder the seats for the bulb holders back on the wiring. I've also seen where they have gotten too hot and the bulb holders have melted. Have to pull them out and see. There are 4 in total.
I don't remember 100% but maybe the fan symbol lights up when you slide the top lever to the right on an SC.
pavegeno 11-21-2016 09:30 PM
When you turn the vent fan on, more lights come on.
DRACO A5OG 11-21-2016 09:36 PM
+1 doable, just a real PITA to do, if you remove the seat, it will be more comfortable.
http://thumbs.ebaystatic.com/images/...TsC/s-l225.jpg
These are type of bulbs that's in there.
Tori 11-21-2016 09:46 PM
Thanks guys.
Jim, those look like #37 bulbs. Wonder if LED's are available. I'll dig into that area sometime in the future now that i know what to expect.
Also, did you guys know the up and down pointing tri-angles glow in the dark ?
http://forums.pelicanparts.com/uploa...1479793599.jpg
DRACO A5OG 11-21-2016 09:55 PM
Yes, so does the interior door handles :D round buttons
Tori 11-21-2016 09:59 PM
WHAT !!! :D Round buttons ? I gotta run to the garage... brb. SmileWavy
ps.
https://www.amazon.com/Cutequeen-20PCS-White-1-SMD-Lights/dp/B00F6RC4JC/ref=sr_1_1?ie=UTF8&qid=1479794262&sr=8-1&keywords=37+led+bulb+white
Tori 11-21-2016 10:06 PM
Crud, i'm missing my door handle dots. Are those available ? I'm also missing one of my vent control decals. Are those little guys available ?
86 911 Targa 11-22-2016 02:59 AM
Radio.
When I did mine, I pulled the radio.
easy-peasy...
Gerry
jkuntze 11-22-2016 04:38 AM
door handle dots available at host
928 part
Tori 11-22-2016 09:14 AM
928 part
I looked for them here on the host site for a '87 928, couldn't come up with anything. Lil' help ? ;)
Tori 11-22-2016 09:16 AM
...and while we are talking dash lights, how is the lamp above the glove box door supposed to function ? I assume just like the rest of the interior dome lamps ? ON, OFF, or on with doors. ???
DRACO A5OG 11-22-2016 10:10 AM
On, Off and with glove door.
As far as the dot: 928-537-747-00 Luminous Glow Dot For Door Handle Fits 911 1987-95 928
Tori 11-22-2016 06:07 PM
Thank you brother Jim. I've got them in my "project list"
RSBob 11-22-2016 08:33 PM
Oh, if you want to be 100% correct, which is highly overrated unless you are anal, then it's a way of life, there should be a light in the ashtray. Great way to keep you an eye on a joint if it went out. You are not anal if you let the joint go out, you are doing it just right.
