Dash lighting - not instruments
As a newb, i'm not quite certain what is supposed to be illuminated on the dash....
At night i see the Defrost symbol it lit on the right side of the heater/vent controls, but the left side seems dark. I assume there is a bulb out. What all is supposed to be lit ?
1987 911 Carrera Coupe 1987 Buick Grand National 1971 Plymouth Roadrunner |
Banned but not out, yet..
Everything on the left of the wheel is dark. On the right rear window defrost and both sides of the air control levers box should be illuminated, but good luck getting your hands back there. Otherwise everything is pretty dark. Using a small screw driver you can pry off. The faces of the knobs and take a look for yourself.
An air cooled refrigerator. ‘Mein Teil’ Last edited by RSBob; 11-21-2016 at 08:31 PM.. |
You can replace the bulbs by laying on your back in the drivers footwell and pulling the bulb holders out from behind. It's a bit of a PITA but doable. I found mine were in pretty rough shape. I had to re-solder the seats for the bulb holders back on the wiring. I've also seen where they have gotten too hot and the bulb holders have melted. Have to pull them out and see. There are 4 in total.
I don't remember 100% but maybe the fan symbol lights up when you slide the top lever to the right on an SC. |
When you turn the vent fan on, more lights come on.
2002 GMC Yukon SLE - 4AT - Purchased New in 2002 1988 911 Cab - 5MT - Purchased Used in 2005 2008 Cayman - 5MT - Purchased New in 2007 2014 911/50 - #1173 - 7MT - Purchased CPO in 2014 2019 Macan S - 7PDK - Euro Delivery/New in July 2019 |
Member 911 Anonymous
+1 doable, just a real PITA to do, if you remove the seat, it will be more comfortable.
These are type of bulbs that's in there.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Jim, those look like #37 bulbs. Wonder if LED's are available. I'll dig into that area sometime in the future now that i know what to expect. Also, did you guys know the up and down pointing tri-angles glow in the dark ?
Yes, so does the interior door handles
round buttons
WHAT !!!
Round buttons ? I gotta run to the garage... brb. ![]() ps. https://www.amazon.com/Cutequeen-20PCS-White-1-SMD-Lights/dp/B00F6RC4JC/ref=sr_1_1?ie=UTF8&qid=1479794262&sr=8-1&keywords=37+led+bulb+white
Crud, i'm missing my door handle dots. Are those available ? I'm also missing one of my vent control decals. Are those little guys available ?
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Radio.
easy-peasy... Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
door handle dots available at host
928 part |
I looked for them here on the host site for a '87 928, couldn't come up with anything. Lil' help ?
...and while we are talking dash lights, how is the lamp above the glove box door supposed to function ? I assume just like the rest of the interior dome lamps ? ON, OFF, or on with doors. ???
On, Off and with glove door.
As far as the dot: 928-537-747-00 Luminous Glow Dot For Door Handle Fits 911 1987-95 928
Thank you brother Jim. I've got them in my "project list"
Oh, if you want to be 100% correct, which is highly overrated unless you are anal, then it's a way of life, there should be a light in the ashtray. Great way to keep you an eye on a joint if it went out. You are not anal if you let the joint go out, you are doing it just right.
An air cooled refrigerator. ‘Mein Teil’ Last edited by RSBob; 11-22-2016 at 08:40 PM.. |
