XDI2 twin plug tab values / configuration
Hi
I'm installing an XDI2 twin plug setup for my engine. it's a 3.0 liter engine with 10.5 compression piston I use too the schrick camshaft package (like 964 cam I will say with improved dual spring retainer ....) I still use the CIS. I have the MAP sensor too regarding the advanced parameters menu I have the default when choosing a 6 Cyl 4 stroke dual plug - TACH SETUP : 3 - CAM/CRANK SENSOR TYPE : Hall - TDC Setup 11 (tooth 11) - MECANICAL OFFSET : 0 (depend of the hall sensor position with the 11 tooth) now with the ignition advance menu I have a 2 dimension tab (rev and kPa pressure) with advance value start from 14 to 36 I know with a dual plug it should be at max around 20/22 I get 2 other menu initial advance : 14 and dual plug timing split purpose for me is to get a "basic" setup to start and drive the car for 700 miles (engine rebuild) and after I will bring the car to be tune on the dyno by a professional. so I would appreciate if someone can share his configuration to avoid to do a mistake thanks for your help |
| All times are GMT -8. The time now is 02:06 PM. |
