Can someone identify this part?
It looks like some kind of jack placement mount, but I am missing on my passenger side.
I'd like to just replace both of them... opinions?
Any idea what this is called so that I can see if our host sells these or some other supplier??
Thanks!
1987 Porsche 911 Carrera Coupe
Old 10-17-2017, 06:40 PM
That’s the jack receiver .
Probably in pet under “collision”
Old 10-17-2017, 06:48 PM
Unfortunately anything I search on a jack receiver seems to be for the jacking location along the rocker panels. Not this part located under the car near the rear sway bar mount.
Old 10-17-2017, 07:00 PM
Btw , a lot of euro cars see problems with rust under the lifting pad , to the point you can poke a hole through by pushing a screwdriver in the hole in the lifting pad
Seeing as your has damage in that area , I’d drill out the spotwelds holding on the lift pad , and remove it to see if any repairs are needed before you weld a new pad on ....
I’d also by a jacking puck whilst you’re buying the repair piece , as unless you have a lift an hydraulic floor jack can slip and slide a little when lifting . An aftermarket “puck” helps secure the jack into the hole in the lifting pad .
Old 10-17-2017, 07:04 PM
It was a part that got added on around 1987 iirc , the year your car is .
Try searching lift reliever , or lift pad .
Old 10-17-2017, 07:05 PM
Thanks... The passenger side is missing this piece and there are holes in the bottom where this piece probably used to be... that's why I need to find it and order a couple to replace them both.
Trying to find it on the interwebz seems to show that the same mount style was used on later model 911s as well.
I contacted some other well known vendors that supply restoration sheet metal and even they want me to send a picture to figure out what it is.
Old 10-18-2017, 07:06 AM
Tell them you’re talking about the lift pads porsche fitted around 87 to enable cars to be lifted on 2-post lifts .
Or maybe try an email to England where this area is being repaired all the time ?
Tutthills , canfords , brays etc will know what you’re talking about straight away ....
I’m now on an iPad so can’t get pet , so the best I can do is get links to the places mentioned above .
http://www.tuthillporsche.com
https://canfordclassics.co.uk
https://www.rogerbrayrestoration.com
Old 10-18-2017, 07:53 AM
Just had a quick look through those 3 websites searching for “lift point” , “jack point” etc and came a cross this ...
Search for "Jack " - Tuthill Porsche
Old 10-18-2017, 08:12 AM
Yep... it is definitely a trap for road debris.
Just wish I knew the actual part # for it... Being that it is a common place for rust, I'm surprised this part isn't as common as the jacking point tube along the rockers.
Old 10-18-2017, 08:40 AM
If you get in touch with them guys and explain your in Usa , but an ex-uk guy recommended them they should give you the info even if they don’t sell them you .
Old 10-18-2017, 08:48 AM
lake wales fla
bracket for jacking point
i believe this is what you are looking for but not 100% positive.if you have access to PET go to illustration 801-20 for 1987 911 between pos.7 and pos. 10 you will find part# 911 507 535 00(LS) and part # 911 501 836 00 (RS), description is bracket for jacking point. there is no illustration or pos. # hope this helps, richard
Old 10-22-2017, 07:42 AM
lake wales fla
just reread post,looks like you are looking for the rears, i believe the # numbers i posted are for the frts. i will look again when i have time richard
Old 10-22-2017, 07:51 AM
