Misfire after 20-30 minutes of driving. 2.8L
2.8L twin plug high compression engine with 46mmPMO carbs. Newly rebuilt with about 1000 miles on it. Ran fine the first 1000, then it started misfiring and losing power after driving for 20-50 minutes. I turn the engine off and open and close the fuel tank and it runs fine immediately. We have checked the venting and it was fine. The fuel pressure regulator is set at 3.5lbs. Will change the fuel pump next. Initially thought it was a vapor lock and then thought it was the fuel pressure. But hard to figure out since as soon as the car is turned off and back on, it is fine. Thanks ahead of time.
Old 08-30-2020, 07:45 PM
Welcome to the forum. I've found lots of help here.
Any "venting" or obvious pressurization of the fuel tank when you opened it?
Old 08-30-2020, 09:31 PM
No. I even drove with the tank open to the air and covered with a cloth to make sure nothing could get in it, while keeping the tank protected. The engine actually started to misfire after just 2 miles.
Old 08-30-2020, 09:57 PM
ROW '78 911 Targa
timmy2's Avatar
Fuel filter(s) full of sediment?
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 08-31-2020, 01:06 AM
I think Dennis is correct. You should have a filter for each carb. PMO sends 2 filters with new 46's.
gary
70T coupe forever almost done
88 Carrera Targa diamond blue
Old 08-31-2020, 05:32 AM
I would rather be driving
jpnovak's Avatar
Check fuel strainer sock in the tank for sediment. Of course, it goes without saying to check the fuel tank itself and make sure its clean.
What ignition system are you running? I would also check each plug carefully with a timing light to make sure it is firing on all cylinders. Is it possible that your ignition boxes or coils are overheating? Is dwell (if you are still running points) set correctly?
Old 08-31-2020, 07:17 AM
How old is the fuel in your tank?
Old 08-31-2020, 08:09 AM
New-ish 911SC Targa Owner
pampadori's Avatar
Have you ruled out the CDI? I recall they fail after driving a while then come back to life after a short shut down.
'83 Targa 300k w/ freshened 3.0 with 930/52 case# 6770540 ARP and Raceware hardware - AEM Infinity 506, Triumph T595 ITBs, B&B headers, Dynomax muff, Fidanza FW, Alum PP-203whp
Old 08-31-2020, 08:13 AM
Have not checked the fuel filter. All fuel lines have been replaced. Fuel has been replaced multiple times, mainly because I keep driving it everyday to see if the problem is getting better or worse.
Old 08-31-2020, 08:34 AM
Tank is clean. Been emptied and checked. MSD with job racing twin plug set up. Definitely think overheating could be an issue. Boxes are set on top of each other rather than side by side.?
Old 08-31-2020, 11:10 AM
Car started to misfire today as I was driving and luckily I was right next to a Porsche shop. Pulled right in and they felt it was electrical in nature as well, especially since it was perfectly fine after we turned the car off and restarted it. I have msd boxes. Will keep you posted. The other option may be the distributor cap?
Old 08-31-2020, 07:47 PM
jpnovak's Avatar
What is your plug gap? It is common to open the plug gap with MSD and they can usually handle the extra current driving the larger gap. However, if you go too far, the internal coil drivers can overheat and start to thermally protect themselves.
Place your hand on the MSD box and coils to see if they are hot.
Old 08-31-2020, 07:52 PM
jmz jmz is online now
jmz's Avatar
check your plug wires. make sure you don't have something shorting out. but if you have isolated it to fuel problems then maybe you need to check all fittings and connections. ...and as jamie said check the sock.
-Jay '74 Mexico Blue 911 3.0 EFI (Fast and Loud)
'70 914/6 Race Car (Faster and Louder)
'71 73RSR tribute vintage race car 3.0
'68 SWB 911T "RENNRAT" 2.8 twin plug/915 gearbox
'81 Magenta IROC clone in progress 3.6 varioram/G50
Old 08-31-2020, 08:47 PM
