Rear Seat Questions
Looking to replace my rear seat seatbelts with eye bolts, and to pull one seat back to make some room.
Can you guys tell me what the thread count and pitch is for the seat belt anchors? Also, is it possible to pull just one side of the rear seat backs? I was told that it might not be possible to just pull one; that you might have to pull both simultaneously. Thanks.
89 Carrera 3.4 "There is a right way to go around a corner - it's called the line." -- PCA DE speaker bryteside.com - good things happen. |
Standard size for all seat belt bolts. Any harness eyebolt you source should fit.
Mat P 1988 911 Carrera |
Member 911 Anonymous
+1, not metric but SAE bolt due to DOT regs
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Appreciated. Do you know whether one can remove the rear seat rests in an 89 individually?
Yes you can.
