Alex599's Avatar
Did I get Fuched?
Howdy Pelicans,
I just had a nasty surprise this morning. I was looking at my tires closely and noticed that they are 15". That seemed strange as I remembered having the 395 option code under the hood; 16 X 6-7 Fuchs. (I've owned the car for two months, still discovering stuff...)
So I removed a wheel and here's what I found. Nockoffs?
There are three inscriptions
MAXWHEEL
LOAD 1000 lb
15X8
Fuched?
1984 Carrera 3.2 Cabriolet
Old 01-03-2017, 02:27 PM
MBAtarga's Avatar
those are not Fuchs.... well that one anyway.
Mark
'83 SC Targa - since 5/5/2001
Old 01-03-2017, 02:41 PM
Cars and Cappuccino
tdw28210's Avatar
They are fakes. So if you bought the car expecting genuine Fuchs, then yes - you were fuched.
http://www.carsandcappuccino.com
1987 Grand Prix White "Outlaw" Turbo Coupe w/go-fast bits
1985 Prussian Blau M491 Targa
1977 Mexico Blue back-dated,flared,3.2,sunroof-delete Coupe
1972 Black 911 T Coupe to first factory Turbo (R5 chassis) tribute car (someday)
Old 01-03-2017, 02:42 PM
Once you wear out the current tires (if their date codes are fairly recent), these would be nice wheels for winter/snow tires
Looking on the bright side, 16x7 front and 16x8 rear fuchs fill out wheel wells a lot better than the 16x6 and 16x7 combo listed on the option code.
Old 01-03-2017, 02:44 PM
MBAtarga's Avatar
Google search results from MAXWHEEL:
MAXWHEEL Fuch Copy???
Fuch replicas by maxwheel. Off an early car 8x15" – Plyhammer's Parts
https://www.tapatalk.com/topic/926261-844
Mark
Old 01-03-2017, 02:46 PM
MBAtarga's Avatar
Where does 16x7 and x8 come into play for the OP?
Mark
Old 01-03-2017, 02:47 PM
Mark:
It didn't, but as a new owner/member/poster that may well be looking at rectifying the situation, it seemed worth mentioning to the OP-- especially since I don't believe that a 16x7 rear would fill the rear wheel wells like a 911 offset 15x8 would.
Would be unfortunate for the OP to pick up a set of 16x6 and 16x7 wheels only to find that they didn't leave him with the look/etc. he had or was looking for (i.e. don't want him to be "Doubley Fuched")
Old 01-03-2017, 03:15 PM
Checked out
McLovin's Avatar
Not just fakes, really bad fakes!
Old 01-03-2017, 03:22 PM
Rescuer of old cars
Arne2's Avatar
MAXWHEEL is not a brand, but part of the wheel load description spread across two petals:
MAX WHEEL LOAD 1500
This makes me think these might be American Eagle replicas, as those are the only reps that I can recall seeing that disclaimer on.
2018 718 Cayman 2.0
Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0
Old 01-03-2017, 03:27 PM
Alex599's Avatar
Well I'm done crying now...
Would 16x9 rear and 8 front be a little much? I found a set of 4 for $5600CAD ($4200USD) with new potenzas Re-11s
Old 01-03-2017, 03:42 PM
unless you have a widbody/turbo look, you'll have a HARD TIME fitting 911 offset 16x8 wheels up front (many folks with non-wide body 911s - including me - needed to roll their front inner fender lips for clearance when running stock 205/55-16 tires on 16x7 fuchs) -- further, the 245/45-16 tire size required for the 16x9 rears is currently only available in potenza RE-11s -- which are great tires, but significantly limits availability. 16x8 fuchs work with the more common 225/50-16 tire size.
further, since 16x8 and 16x9 fuchs are both relatively scare "unicorn" sizes, you may well find yourself doing a lot better $$$-wise going with 16x7 (very common as rear wheels) up front and 16x8 (or 16x9) on the rear.
Another option (ironically) is to consider the new variety of fake fuchs in 17" diameters.
Old 01-03-2017, 03:47 PM
LakeCleElum's Avatar
I recently sold 2 of those. 15 x 8....Got about $300 for 2 as I recall.
Bob S.
73.5 911T
1960 Mercedes 190SL
Old 01-03-2017, 04:02 PM
Alex599's Avatar
Thanks Darrin, that clears things up. I'll go with 7s and 8s
Old 01-03-2017, 04:12 PM
Alex, lets see a pic of the car. Not many Carrera's running around the remote corners of BC. I'm betting not ideal driving conditions in Golden this time of year either.
Mark.
84 911 Targa Carrera currently getting renewed
Old 01-03-2017, 06:06 PM
sugarwood's Avatar
One vote for leaving them until the rest of the car is sorted.
Just enjoy the car. Give it a week and you'll get over this.
Or you can get new replicas in 16 or 17 for $180/ea
https://www.google.com/search?q=euromeitster+fuchs+replicas#q=euromeister +fuchs+replicas+
1986 Bosch Icon Wipers coupe.
Old 01-03-2017, 06:54 PM
Alex599's Avatar
Mark.
Hi Mark, I just bought the car from a widow in Vernon. The car spent its whole life in the okanagan. It still has a good four months to go before it touches asphalt. I don't have good pictures but the car is sound. I'll take some good ones in the spring.
Agreed, no rush. I think I might polish, paint these in the mean time. It might be good practice for when I buy the real deal.
Alex
Old 01-03-2017, 09:59 PM
Rescuer of old cars
Arne2's Avatar
Another thought. Don't over look the thought of reverting back to original '84 spec of 16x6 & 7 rather than going for 7 & 8. Those fit great, and with a pair of 1" spacers on the rear fill the flares well. Generally a lot cheaper than the wider sizes too.
2018 718 Cayman 2.0
Old 01-04-2017, 07:35 AM
Alex599's Avatar
That's a sexy vehicle right there Arne. I'll definitely be going that route!
Old 01-04-2017, 07:56 AM
Rescuer of old cars
Arne2's Avatar
The narrower wheels are a better fit up front, and can look good in back with spacers. And far more affordable. Here's an example. No affiliation.
16" Fuchs 6s & 7s 911 Fitment $1100
2018 718 Cayman 2.0
Old 01-04-2017, 09:10 AM
another option -- 16x7 all around -- running the 16x7 up front (without spacers) will fill out the front wheel well and the 16x7 rear with spacers will fill out the rear.
Keep an eye out in the classifieds for used pairs and have them all refinished as a set
Old 01-04-2017, 09:42 AM
