DP Motorsports project sleeper 3.2
DP Motorsport Project Porsche 911 Sleeper Pictures, Pricing and Specs
I dont remember seeing this car? I remember a white one. Anybody have any more details - how did they get the weight below 2000 lbs? |
Side rockers and rubber Engine Seal Rubber, struts ( Maybe more ) Back Seats Probably replaced allot of panels with plastic, maybe bumpers and bumper struts, etc etc. |
looks great, serious weight loss though.. no idea how they got it that low
based on the article....
carbon fiber panels metal supports drilled to swiss cheese, leaving only minimal structural stiffness titanium exhaust minimal interior AC and heat removed plastic and rubber bits removed plexiglass windows and of course... a "thin coating" of paint...:rolleyes: But seriously.. titanium exhaust and carbon fiber panels will save you a lot of weight... that's probably at least 200+lbs? lightweight seats... and other interior bits... another 150lbs? comfort parts removed (heat, AC) another 100lbs? glass and all the rubber and plastic bits... another 100lbs.? finally cutting and drilling out extra metal. Depending on carbon fiber usage... if you replaced all panels, gas tank, roof, and other components with carbon fiber... that would be a lot of weight. |
Spec 911's can barely get to under 2,200lbs and there is absolutely nothing left of those cars. This one still retains a semblance of a street car |
Shows the bumper blades are carbon fiber. That's pretty cool. Wouldn't mind having a set of those.
The DP car is pretty much the same weight as mine, give or take a couple gallons of fuel. |
Yeah if I remember right the following parts on the white car were CF - probably the same here:
Roof Hood engine cover bumpers front fenders engine shroud and tin Seats more I cant remember |
Wow that link to the German DP site is cool. That dash board set up looks really nice.
Ballast on the Spec 911's is usually for lighter drivers. My direct comparison would be my Carrera Spec/Spec 911 race car. Still has metal fenders/hood and rear quarters, but other than that there is not even a superfluous bolt in the car; literally nothing left to be lighted/removed without cutting into the tub (doors weigh 30 lbs together). That car weighs just under 2,300 with fluids. |
I don't know, your cage is probably much more extensive than the DP car and the steel panels are still going to be quite heavy. My car could still loose a few more pounds.
Anyone has video's of this car with titanium exhaust?
Expensive pricing on the site for the lightweight materials :o |
(pics only) |
It's kind of killing the idea when you write "Sleeper" on the deck lid. Awesome car nonetheless!
Nice car and likely very quick with all that weight removed. But they could have saved a few more grams by cutting off the airbox cover... ;)
And I don't know, but with the rockers removed on impact bumper cars, in a profile view, they look like they're sucking in their gut. http://forums.pelicanparts.com/uploa...1480566727.jpg |
Would be more balanced with no front spoiler and a tad less rake. And yes, the "Sleeper" badge and boy racer fenders sticker don't seem in line with the cars title. |
It does say in the article linked above that they got the car "a little less than 905 kg (about 2000 lbs)" ... |
The power-to-weight ratio is dead on with a C5 Z06 Corvette.
Those cars moved pretty decent. |
The site said they were getting around 270HP with ported heads, different cam but stock air meter. Doesn't that seem suspiciously high?
| All times are GMT -8. The time now is 11:18 AM. |
