El Duderino
Right in front of the glovebox on the downward facing lip of the dash. Find the light and there is a 3-position setting switch to the side.
This is a pretty good guide to explain the process of finding a parasitic drain. https://www.google.com/amp/m.wikihow.com/Find-a-Parasitic-Battery-Drain%3Famp%3D1?client=safari You want to use the fused amperage setting of your meter. It's commonly a 10A, 15A or maybe 20A setting. You're doing this with the car off otherwise you would blow the fuse in the meter. The basic process is to hook up the meter in line to the negative battery cable and then pull (and put back) each fuse until you find the one that has the draw. Once you find it, then you isolate everything on that fuse until you find the problem.
There are those who call me... Tim '83 911 SC 3.0 coupe (NA) You can't buy happiness, but you can buy car parts which is kind of the same thing. Last edited by tirwin; 12-06-2016 at 05:29 AM.. |
Coram Deo
Dru 1980 911SC Targa Petrol Blue Metallic Cork special leather Sport Seats Limited Slip 964 Cams SSIs Rennshifter 1990 250D Opawagen 1995 E220T Sportline Familienwagen 1971 280SE Beverly... hills that is 1971 Berlina 1750 Faggio |
El Duderino
Yes.
There are those who call me... Tim '83 911 SC 3.0 coupe (NA) You can't buy happiness, but you can buy car parts which is kind of the same thing. |
