Seat belt mounting
I am in the process of mounting new seat belts in my car. I've taken the side panels off and removed the plastic bolts that were in the holes in the picture. I measured the plastic bolts with a micrometer and came away with a measure of 10 mm diameter and 1.25 pitch. Yet, when I screwed in the bolt, it was a loose fit. I could wiggle it in the hole. The thread pitch is OK. I had the same problem with the hole in the other side. What size should these bolts be?
Steve B.
1972 911t
1999 328is
Old 12-05-2016, 01:02 PM
Irrationally exuberant
ChrisBennet's Avatar
They are SAE thread 7/16-20, not metric. I have no idea why.
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 12-05-2016, 01:18 PM
Wow. I never would have guessed. Maybe Porsche had to comply with some US safety dictate when imported in 1972.
Steve B.
1972 911t
1999 328is
Old 12-05-2016, 01:24 PM
HarryD's Avatar
This size is standardized worldwide. All seatbelt hardware uses this thread. The shoulder and head may be different for your application.
Use SAE Grade 5 bolts. Higher grades can be too brittle.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 12-05-2016, 05:46 PM
I went through the same thing years ago with the bolt on the "B" pillar. I was making a fitting so that the pillar could be attached to the roll bar, and help stiffing the structure. I could not figure out the metric thread.
I went to a Hot Rod parts store, and the counter guy said....."you sure it is not SAE?"
He said many metric cars had SAE seat belt attachments.....he was right!
RGruppe #79 '73 Carrera RS spec 2.7 MFI
00 Saab 95 Aero wagon stick
01 Saab 95 Aero wagon auto
03 Boxster
90 Chevy PU Prerunner....1990
Old 12-05-2016, 09:36 PM
