RETIRED
Joe Bob's Avatar
I had inconsistent clicking on my DME relay. It ended up being a bad power fuse. The ends had been worn off and did not allow for a good circuit path.
2012 ML350 3.0 Turbo Diesel
Old 12-07-2016, 03:24 PM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
Sounds like a spotty DME relay and your alarm module isn't satisfied or broken.
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 12-07-2016, 03:30 PM
Originally Posted by handleyb View Post
Dave,
Yes if I connect Pin 30 to Pin 87 ( no ground to 85b) the car runs.
I connected pin 30 to Pin 86 without any results. Brian
1. Time for a good DME relay.
2. Jumper pin 86 to 87 but only turn the key on without cranking the engine.
Then place your hand on the idle valve to see if it's vibrating.
It the valve is vibrating, you have power from the ignition switch thru the alarm
ECU to the relay and your problem is just a bad relay.
3. Remove the jumper before any cranking of the engine.
Dave
Old 12-07-2016, 06:03 PM
Turned out to be a problem with my alarm system. Today I bypassed the alarm using the "no cut" method mentioned in the Forums. Car is running , owner is happy. Thanks for everyone's input.
Brian
Old 12-11-2016, 05:54 PM
RETIRED
Joe Bob's Avatar
Now you should remove it....
Old 12-12-2016, 05:25 AM
