Plug wires
I was looking through the maintenance records I got when I purchased my 1984 Carrera. Looks like no one has ever replaced the plug wired. Anyone know the difference between the Beru and the PVL wires? And if I ohm the old ones out just for grins, what should the ohm range be?
3.3 ltr, stock compression, efi, twin turbo - no intercooler. |
The first thing to check with old wires is if the case has degraded and is allowing shorts. Go into the garage at night and start the car up, with all the light off take a look at the engine. If the casing on the wire is bad (and it most likely is) you will see small arcs from the lines to ground.
A visual inspection may also reveal bad/cracked/degraded casings. Our host has lots of great choices for replacement wires. I dont know the ohm range off hand but I would check all 6 for consistancy if you are worried. Regards Dave
'78 911SC Targa (Back In Action!) '00 996 Carrera (New kid on the block) '87 944 (college DD - SOLD) '88 924s (high school DD - Gone to a better home) |
I would think after 30 years and more than 200,000 miles, they are probably not in the best working condition.
I'm still running the original wires that came with my '86 targa (175k miles) -- they're not super pretty, but don't arch or provide any other signs of distress/problem. I'm staying in the "if it ain't broke" camp on this for the time being and focus on timely replacement of wear items (rotors, plugs, etc.)
Rescuer of old cars
Maybe, maybe not. Like you, I have an '84, mine has only 170,000 miles. Also like you, there are no mention of plug wires in the extensive records I have for my car. But when tested in the dark of night, my car's engine compartment is totally dark. And the car runs great. So I've not bothered to replace mine so for. I look them over at least once a year, including the night test.
2018 718 Cayman 2.0 Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0 |
Vintage Motorsport
Spark plug wires are easy enough to check.
Spark plug wires don’t wear out as much as they suffer damage when being removed. The biggest cause of damage is caused by removing the wire from the spark plug. ![]() Richard Newton Electrical Tools |
I looked in the factory manuals and no specs were given. But it did say their were 2 types of rotors. A 1k ohm and a 5k ohm, and said always use the 1k ohm. In the past I have seen the extensions at the end of the plug wire go bad and arc across rather than fire. Reason I am looking into this, sometimes it misses when accelerating from start and wideband shows richer like unburned fuel. But problem is random. It does not due it at cruize, and pulls good at wot. Also idles great.
FYI, I replaced my wires last year only because one was broken. But, all of the coverings were showing signs of wear. I have an '85 Carrerra with ~68,000 miles.
The readings at the time were: old wires: #1 open circuit: plastic connector- .9 M ohms, wire- 3.0 ohms #2 3.08 kohms #3 2.8 kohms #4 2.92 kohms #5 3.07 kohms #6 3.08 kohms New wires, Pelican, Beru: #'s 1-6 2.9-3.3 kohms coil wire 0.0 kohms. I don't have the information RichardNew has above as to whether or not they were inductive or carbon resistor type. The Pelican information did not state this.
1985 911 Carrera Targa, 2011 911 Carrera S 997.2, 1951 Harley Davidson Panhead Chopper, 1957 Harley Davidson Panhead- stock, 1972 Yamaha 250 DT-1(sold), 1959 Austin Healey (Bug Eye) Sprite- sold, 1959 Austin Healey (Bug Eye) Sprite- sold, 1960 Austin Healey (Bug Eye) Sprite- sold |
Ohming ignition cables is meaningless since it tells you nothing about the integrity of the insulation and it's ability to contain high ignition voltages. A more significant test would be with the application of some liquid, like windex, on the cables while at idle.
In the industry, high tension cables are tested with a Megger tester capable of 15kV or more. Not the sort of equipment we could afford or have lying around our garages which is why I recommend windex. Cheers, Joe 87 Carrera which passes the Windex test! |
