Easy Tiger
Easy Tiger's Avatar
Mystery Engine
Hi All,
Have a CIS issue, but first I have to know the year and spec of my engine (not original to my '77 Euro SC):
930.106.102.OR
*6290943*
Any takers? Cheers.
http://911backdateproject.tumblr.com/
Instagram: the_unofficialghost
Old 11-06-2016, 06:11 PM
It's a 79 SC 3.0 for the US market
1970 911E Sportomatic Albert Blue
1971 911T Sunroof Coupe w/ Twin Plug 2.5 MFI
1973 911E Glacier Blue
1973 911E RSR Tribute Viper Green w/ 3.5 Twin Plug MFI
Old 11-06-2016, 06:13 PM
Easy Tiger
Easy Tiger's Avatar
Cheers!
Old 11-06-2016, 06:17 PM
Easy Tiger
Easy Tiger's Avatar
Next question; What is the correct distributor model for this engine?
Old 11-06-2016, 07:21 PM
Mixed engine component/s.........
Originally Posted by Easy Tiger View Post
Hi All,
930.106.102.OR
*6290943*
Any takers? Cheers.
Easy Tiger,
Yes. You have a '79 SC USA engine with a ('81 ~ '83) 245-mm alternator fan and housing. What is the number on your WUR? -045, -069 , or -089? How about your fuel distributor? Keep us posted. Thanks.
Tony
Old 11-06-2016, 07:25 PM
Ignition Distributor should be 0 237 306 001
Old 11-06-2016, 07:37 PM
Easy Tiger
Easy Tiger's Avatar
Cool, thx.
I'll check my distributor serial and see if it matches...
Old 11-08-2016, 09:08 AM
Easy Tiger
Easy Tiger's Avatar
Ok, my distributor number is: 0 237 304 016
Is this a problem?
Also, what would be the correct WUR model for this engine?
Old 11-08-2016, 09:27 AM
Easy Tiger
Easy Tiger's Avatar
Current CDI is 0 227 300 004
Old 11-08-2016, 10:16 AM
Mixed match CIS components.......
Is this a problem?
ET,
You have the wrong ignition distributor for your engine. Could you check the ID numbers for the fuel distributor, AAR, etc. Does the engine have a decel valve? And take a picture of the engine for visual test. Use a pressure gauge to check your WUR's fuel pressure delivery.
Tony
Old 11-08-2016, 01:38 PM
Easy Tiger
Easy Tiger's Avatar
Hi Tony,
Thanks for the direction, I'll try and get a list of the CIS components and check compatibility.
Old 11-08-2016, 06:16 PM
Easy Tiger
Easy Tiger's Avatar
The Plot Thickens...
Hi All,
Thanks to the Pelican community I have learned some important things about my car, specifically the engine.
Here's my update:
Body: 1977 Porsche 911 3.0 SC Euro Model
Engine: 1979 SC 3.0 USA Spec Engine
Ignition Distributor: 0 237 304 016 (should be 0 237 306 016)
WUR: 0 438 140 089 (matching?)
CDI: 0 227 300 004 (matching?)
I'll poke around the engine and see if I can get the numbers for the Fuel distributor and Auxiliary Air Regulator (AAR)
Old 11-09-2016, 08:53 AM
Since there was no 1977 SC, you might post your chassis number to see if you have a '77 911, '77 Carrera 3.0, or 1978 SC.
JR
Old 11-09-2016, 09:41 AM
Easy Tiger
Easy Tiger's Avatar
It's my understanding that there was a German '77 SC, which is mine. 2.7 Case with bigger headers.
Old 11-09-2016, 03:26 PM
Nope. They got the SC in 1978, just like we did. Post you chassis number and I'll tell you what it is.
JR
Old 11-09-2016, 03:33 PM
Bland
unclebilly's Avatar
What is your VIN?
If it is 911720xxxx - you have a 77 911 US coupe that came with a 2.7.
If it is 911730xxxx - you have a 77 911 Japan coupe with a 2.7.
If it is 911760xxxx - you have a 77 911 Carrera coupe that would have came with a 3.0 engine.
If it is 911820xxxx - you have a 78 911SC US coupe that came with a 3.0 engine.
If it is 911830xxxx - you have a 78 911SC ROW / Japan coupe with a 3.0 engine.
Old 11-11-2016, 05:03 AM
Paper Member
Mystery Engine
My '78 SC was actually built and delivered in mid '77, but it's one of the first SCs built. Maybe he's looking at a build date.
Enemy of the State
Brandolini’s Law: It takes hours more time, research, and writing to debunk misinformation than it takes to spread it.
Old 11-11-2016, 06:35 AM
In some markets, a car gets titled according to the date of production, or the date of first sale. That may be what is at issue here.
Thee are quite a few differences between a '77 911 and a 911SC, so he might as well figure out what he has. I suspect it's a ROW '77 911, but who knows?
JR
Old 11-11-2016, 06:53 AM
Bland
unclebilly's Avatar
JR
Well if he compares his VIN to my above post, he will know what he has and then can report back.
Old 11-11-2016, 07:07 AM
What is interesting is that the tach that is in his car is not from a 2.7 911 but from a Carrera 3.0...
JR
Old 11-11-2016, 07:18 AM
