pjv911's Avatar
Send a message via AIM to pjv911
Is this a good tranny to use for a 3.6 conversion ?
This guy is very local. I am starting to round up my needs for the 3.6 conversion on my 69` . I have yet to decide which transaxle to use. This is a 930 5spd unit right ? Whats it worth considering it to be good ?
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=33733&item=1876609741&rd=1
Kurt Williams
Never drive faster than your gaurdian angel can fly.
82 SC w/965S eng and G50 6:1 hp/w ratio
72 911t 2.6 twin plug and 72' 911t 57k orig 1 own miles
65/66 912 1 owner 76k orig
01' Aston Martin DB7 V12 Vantage Coupe 6spd
Old 01-11-2003, 03:53 PM
Bill Verburg's Avatar
Kurt, I would suggest an '84-86 915 for the following reasons,
  • relative ease of installation
  • relative cost of the installation
  • it's the strongest of the 915s
  • even my mg case 915 lasted 9yrs because it was never abused on a race track
  • for track use install an electric cooler & if you really want reinforced side plates
  • weight is much less than G50/930 alternatives
Bill Verburg
Old 01-11-2003, 04:01 PM
pjv911's Avatar
Bill if this tranny can fit without modifying the torsion tube I would have no problem working out the install. Is this tranny a 915 ,930 5spd or a g50 ? I plan to drag race the car as well. I dont want to worry to much about the tranny breaking. If you dont mind could you explain why not to use this unit. Also would this tranny allow the use of a cable clutch ? How about clutch options for this unit.
Kurt Williams
Old 01-11-2003, 04:08 PM
It looks like a G50, the 930 was an early version of the G50, they all used the bigger 240mm clutch as does the 964. All of the G50s will require at minimum the '87-89 torsion tube or alternately removal w/ installation of coil overs. I think that the very expensive shortened version will fit w/ a modified torsion bar tube. The 4spd 930s used a cable clutch, the 5 spd a hyd clutch
For drag racing I guess that you may be forced to go to the hassel and expense none of the 915s will live long if bused in that manner.
Bill Verburg
Old 01-11-2003, 04:22 PM
I think that is a 4 speed 930 box. You could fit that tranny but you would have to shorten it.
Dean
911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno,
Old 01-11-2003, 04:53 PM
