-   -   3.6 conversion, check engine light/V belt failure light (http://forums.pelicanparts.com/porsche-911-technical-forum/93866-3-6-conversion-check-engine-light-v-belt-failure-light.html)
Joe Bob 01-11-2003 01:42 PM
The smog weenies need me to put a check engine light on my dash....since I
have removed the front bumper an gone with an RS type the highly used (not)
headlight washers are gone and there is no need for the rocker switch on the
dash.....
So, I figure putting a light there would be a good idea.....while looking at
the wiring diagram. http://www.di.com/home/ingo/Conversion/harness.jpg
I noticed the V-belt failure warning and the check engine light are on
separate circuits and use two separate bulbs.....
Does anyone know of a dual bulb set up that will fit in the rocker switch
area that I can use? 12volt with a simple ground attachment is all I need.
Rather buy something off the shelf than re-invent the wheel.
Mike Z, daddy of three gorgeous gals..
9 Eleven Motors, CA licensed and bonded dealer
65 356 C Karmann Coupe #219593
73 914 2.0, Karmann Targa
83 911 cab, 3.6...duck tailed and going retro.
http://www.9elevenmotors.com/
widebody911 01-11-2003 02:45 PM
Try Radio Shack or HSC or one of those types of places.
I was going to put mine in where the EGR light is; you might have a hole there already, behind the dash covering. But, as it turns out, I didn't need a light, soo...
Are they requiring you to install a belt light, or is that just for your own peace of mind? I solved that one by going to a single belt.
Joe Bob 01-11-2003 04:00 PM
Gonna do the belt light as it is a common failure.....no EGR but I found some lights at Summit and I will get them while I get the Supertrapp caps with the probe hole....
