Help Locating Placement of Hose
In the attached diagram I see where hose number 30 goes to the middle of the air valve. But I cannot see where hose #29 goes to---Does it also connect to the air valve---but where I cannot make it out in the diagram.
ALso, is hose #29 connected to the brass nipple in the back of the engine that is shown in the second picture (next to the red circle, not in the red circle)? Thanks everyonehttp://forums.pelicanparts.com/uploa...1482108904.png http://forums.pelicanparts.com/uploa...1482108904.jpg |
http://forums.pelicanparts.com/uploa...1482110800.jpghttp://forums.pelicanparts.com/uploa...1482110887.jpg
^^^^^ Hope this helps. Best, Gerry |
Gerry:
Thanks for the pictures. But without explanation it does not really tell me the two point where the hose connects. I take from your picture the #29 hose goes to the brass nipple, is that correct. And if so, where does the other side connect. If any one can direct me I would greatly appreciate it |
28 is the larger hose from the brass nipple shown to the diaphragm valve that goes to the oil tank breather, 29 is the clamp. 30 is the vacuum hose that goes to the same valve.
Had no idea that hose 28 went to the oil tank breather from the brass nipple. The diagram is misleading because it suggests the 28 hose goes to the air valve. really misleading |
Here's a couple more pictures, #28 & #30 go to the air valve beside the oil tank.
http://forums.pelicanparts.com/uploa...1482260831.jpg http://forums.pelicanparts.com/uploa...1482260831.jpg http://forums.pelicanparts.com/uploa...1482260831.JPG http://forums.pelicanparts.com/uploa...1482260831.JPG |
JrBennett:
Absolutely superb pictures. Using your pictures I was able to locate where the hose #30 goes to the air valve. Did not know the air valve had two nipples on it, one on top and the other underneath. Thanks to your pictures I now got all of my hoses correctly connected. |
| All times are GMT -8. The time now is 05:29 PM. |
