| Registered Join Date: Oct 2015 Location: Eastern Pa.
				Options for Brembo GT replacement rotors?
			Has anyone found rotor options (drilled or slotted) for the Brembo GT 1 pc rotors ? I have searched to no avail,other than brembos drilled 1 pc.replacement rotors. F/R Specs below: Brembo GT front rotor GT-1P_.6001A (GT SYSTEMS)|1986 PORSCHE 911S / SC /Carrera Disc 1P4.6001A2 Disc Type: Cross Drilled Disc Material/Finish:High Carbon / Corrosion Resistant Plating Disc Diameter:323mm Disc Width (Measurement):28mm Disc Air Gap (Measurement):10mm Disc Annulus (Measurement):54mm Disc Construction:1-Piece Disc Disc Vane Design (Measurement):vented Curved 48 Vane Disc To Hat Mounting System:N/A Friction Material Pad Compound:Brembo High Performance FM1000 Pad Volume / Surface Area:76.4 | 62.1 Rear Brake Rotor/Pad Specs GT-2C_.5001A (GT SYSTEMS) | 1986 PORSCHE 911S / SC / CARRERA Disc 2C4.5001A2 Disc Type: Cross Drilled Disc Material/Finish:High Carbon / Corrosion Resistant Plating Disc Diameter:309mm Disc Width (Measurement):28mm Disc Air Gap (Measurement):13mm Disc Annulus (Measurement):54mm Disc Construction:1-Piece Disc Disc Vane Design (Measurement):Vented Curved 48 Vane Disc To Hat Mounting System:N/A Friction Material Pad Compound:Brembo High Performance FM1000 Pad Volume / Surface Area:48.2 | 53.6 Thanks
				__________________ 1979 SC 1986 Carrera 3.6 L+ | ||
|  12-20-2016, 01:55 PM |
