Coupe dome lights...
...do they just pop out? Is there a secret clip, or are they just kinda shoved up in there via pressure?
And the bulbs inside are the bullet shaped festoon bulbs, right? Thanks!
Mike Bradshaw 1980 911SC sunroof coupe, silver/black Putting the sick back into sycophant! |
Member 911 Anonymous
Yes and Yes.
The ends have a metal spring notch that slides in the port. To remove, use a small screw driver and on the same sides you wil see a 1/8" space, that is where the screw driver goes in then you pry.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC Last edited by DRACO A5OG; 12-27-2016 at 04:05 PM.. |
