I run a one in one out m&k with an aftermarket cat on my '86. The m&k is the current design (quieter than the originals). It is a couple years old and has gotten a bit louder over time. I love the sound. I did need to adjust the AF ratio a bit.
Do you think something like this is just too much?
For me? Yes, too much. For you? Don't know.
But don't buy it on eBay, our host sells it too, same price. Fabspeed 911 Supercup Exhaust System FAB911SCUPS32 - Fabspeed Motorsport - FAB-911-SCUPS32 | Pelican Parts |
Unless you change your heat exchangers you will be stuck with a single in. Dual out tends to drone at rpms that are within your normal driving range.
Believe it or not a flat turbo muffler can be fabbed very cheaply at your local indy muff shop. Avoid the Porsche tax. Tell them what you want and they usually will swap one on and let your test it. I ended up just running a sport cat w/o a muffler on mine. |
Another M&K 1-in/1-out vote. Along with M&K premuffler and Wong chip, recently dynoed at 211 RWHP in my '86 US spec targa. Otherwise stock.
And sounds great, no drone. But it is quite smelly due to no cat. Much lighter than the 'lead sausage' stock muffler and cat. |
Nothing wrong with this https://www.youtube.com/watch?v=yWy0r6NOlkM |
Turns out I have a cat by-pass installed currently with what looks like a stock muffler although I'm sure could use an upgrade. Are the OBX cat by pass any good? $100 or so on eBay seems reasonable.
Also, found this but leery of anything custom made. |
SUM-622003 2.5" U-bend pipe - $21.95 WLK-17676 Walker 1 in 1 out same side - $69.95 WLK-31900 Walker 2.5" 3-bolt flange - $3.95 Total: $95.85 Also my first try at welding, lit my pants on fire, and boy do the welds look bad. Has held up well though. http://2.bp.blogspot.com/-N6QfTVjhU2...615_210420.jpg Hear it here. That's with a minimum bullet style cat mandated by the rules, but OE heat exchanges otherwise. |
The OBX cat bypasses have not received good reviews here in the past. Spend a little more and get a good one.
It's fun spending someone elses money!
SSIs and an M&K 2-2 will turn it up to 11.
-e. |
