Certified Pre-Owned
BGCarrera32's Avatar
Carrera seat mount dimensions needed...
Hi:
The car in the picture below is not mine. I am in need of the factory seat mount dimensions for an '84-'89 Carrera as shown. I do not have the mounts in my car as they were removed many years ago so I'm up fabbing new ones which will also sit a bit lower.
If you have this car and have the seats out, I'd be very appreciative of the following:
A) End of the rail to the center of the first hole
B) Front hole on-center to first hole on-center at back of the rail
C) Distance between rear holes center to center
D) Distance across center to center between rail holes (left to right)
E) Overall length of the rail
Angle of the seat rails relative to the door sill
Thank you for any info you can provide!
BG
'84 Carrera Coupe
Old 12-26-2016, 05:59 PM
