is Yokohama ADVAN A052 better than Michelin
Pilot Exalto PE2 or PZERO? |
I have 16x7s & 8s and am running 225/45 and 245/45…they are meaty, but look right…drives great…
http://forums.pelicanparts.com/uploa...1730692955.jpg |
Mine is late G body 89 targa, recommending same size for Fuchs 16X7&8?
Since P7's are out until Feb, Michelin
Pilot Exalto PE2 or Pirelli P Zero Rosso (Collezione)? |
or Yokohama
ADVAN A052? |
I love the handling (stickiness) and ride from my AO52 tires. I can think of two potential disadvantages to them. 1) they're not going to be very durable -- figure maybe 5k miles out of the rears? Not an issue for me, as I run them as summer-only tires and put under 1k miles on them per season -- like most other tires, they'll likely age out for me before wearing out, but this could be an issue if you're a higher mileage user. 2) they're true summer-only tires and (as I understand it) don't even like to be stored (let alone used) in sub 50f weather. Again not an issue for me.
Finally, as track/competition tires with compounds/tread designed for this specific use, they're likely going to be less forgiving in the rain than more conventional tires. Again, not an issue for me as I can be picky about when I drive to minimize rainy weather/monsoon driving. As far as size, I'd consider going with 205/50-16 for the fronts and 225/50-16 for the rears. Some folks (me included) running 205/55-16 fronts with 7" Fuchs have issues with the outer edge of the front tires rubbing against/pulling out one or more of their front inner fender lips. This initially occurred with my right front fender. I understand that going with shorter tires (205/50 vs 205/55) can minimize the possibility of this occurring -- I'd be concerned that the extra width of 225s up front could increase the potential for rubbing. For the rears, I'd stick with 225/50-16 for two reasons. First, 245/45 ao2s are currently on backorder . . . Second, while a 245/45 will fit on an 8" Fuchs, running them on 9" Fuchs is preferable as it allows the sidewall to stretch out a bid more and is overall a better "fit" (in much the same way that 205/55 Fuchs fit better on 7" Fuchs than 6" Fuchs) than the fatter 245/45s |
w/ 7 & 8 x16 Fuchs;
205/55 and 225/50 are the old std sizes 205/50 & 225/50 gives you a bit more room at the lip , useful for lowered cars 205/50 & 225/45 provides better acceleration and a bit more room for lowering in back, though this last isn't much of a concern 205/50 and 245/40 van be used but it's not optimum due to wheel width deficiency wrt to the 245 tire width, you get a cushier ride but the tire is less well supported and moves around more |
came a cross a 16X9 would the tire be 245/45?
Also are the new wheels from Fuchsfelge vs. Original date code Fuchs? |
Not sure what your second question is asking. |
comparison to old stock Fuchs with date code of 80's vs. New items from Fuchsfelge® USA,
which is the better route? will I have any issue with rubbing with 9's? |
old 9x16 is ~15.93# new is ~ 13.15# yes 245/45 is the tire for these wheels, it's a nice choice because it is shorter than 225/50 x16 thus importing a peppier acceleration curve down side if using Fuchs is the the 7x16 fronts pretty much limits you to limits you to 205/50 or 205/55, though you could squeeze 225/45 or 225/50 on the 7s w/ some work |
Thank you Bill
| All times are GMT -8. The time now is 12:49 AM. |
