billh1963's Avatar
Engine Compartment Connector question - 1985 3.2
I'm trying to find out of this connector should be connected. It's in the engine compartment of my '85 on the left hand side of the engine (side with the fuse panel, fuel filter, etc.). The duct to the blower is not in the picture in case you are wondering why you can see the injectors.
The connector has a yellow wire with a black stripe and a brown wire.
The only YEL/BLK wire I see in the Bentley manual for an '85 is one that goes to the air flow sensor. The air flow sensor is connected. Is this a test connector?
Old 12-29-2016, 09:42 AM
engine compartment fan
Good luck
Dave
Dave McKenzie
1984 Carrera 3.2
1984 928S Automatic
2001 996TT
Old 12-29-2016, 09:54 AM
billh1963's Avatar
Awesome...thank you
Old 12-29-2016, 10:22 AM
