Member 911 Anonymous
![]() Hey Fellas, I've been looking for battery terminals and found a whole bunch. I know to avoid lead but what about the other metals: copper, gold, nickle? Sears has the Copper ![]() This would be the starter side: ![]() The FleeBay: Nickle, Chrome or Gold clad ( sears has the chrome) ![]() Anyone know the gauge of our cables? TIA,
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC Last edited by DRACO A5OG; 03-07-2013 at 09:22 AM.. |
Summit Racing has plated Brass:
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Coram Deo
Draco,
1. Why avoid lead? It was standard equipment on every car for generations, and as long as you don't eat or breathe it, it poses no danger. 2. What standard do you want to use for "best"? Cost, reliability, durability, conductivity, resistance to corrosion, malleability? Again, those that designed our cars made their calculation and came up with...lead.
Dru 1980 911SC Targa • Petrol Blue Metallic • Cork special leather • Sport Seats • Limited Slip • 964 Cams • SSIs • Rennshifter • 1990 250D Opawagen • 1995 E220T Sportline Familienwagen • 1971 280SE Beverly... hills that is • 1971 Berlina 1750 Faggio • Last edited by RDM; 03-07-2013 at 09:34 AM.. Reason: more thinking |
Functionista
Lead. Less corrosion, more ductile(won't crack as easy), and my '74 didn't have lead ends from the factory.
Jeff 74 911, #3 I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible. |
Interesting point, realibility and conductivity seems to be the most important thing, I don't want to just replace the terminal with some cheap item at the FLAPS only to have it fail.
French Import
You can't go wrong with copper either, and it tastes better than lead...
![]() Look at the battery terminals and they are probably made of lead for the reasons invoked above. I do like the Fleabay design in your pics as it makes it easy to add separate circuits apart for the stock wiring harness.
Gilles & Kathy Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road! ![]() 86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate |
RETIRED
I use Marine batteries, wing nuts as connectors. They tend to hold up best and tolerate extra connectors. Since I retired and I ride my bike a lot.....my 911 sits a lot with the trickle charger it is the best solution for me.
Brass is good, cuts down on the green fuzz....since you live near the ocean, something to consider.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel Last edited by Joe Bob; 03-07-2013 at 10:50 AM.. |
AutoBahned
solid gold is by far the best
avoid eBay Porsche no doubt has stock ones available Joe Bob - got a pic of what you describe? |
Functionista
Solid kryptonite even better!
unobtanium is by far the best "
RETIRED
If you have a standard battery, use these clamps.
![]() A little more expensive than lead but tend to corrode less and less of an issue on connectivity. Use this type cable ends.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Evil Genius
type of clamping material honestly is irrelevant.
QUALITY of crimps and corrosion free connects = happiness. Use Battery Lube/Grease on all contacts too, it's the red jelly stuff.
Life is a big ocean to swim in. Wag more, bark less.
vince_wa
Battery connectors should always be the same material as the actual battery terminal. If you use different materials you will always get galvanic corrosion. Plated connectors such as zinc are effective ( sacrifical anodes) to help prevent this but what this means they will rot over time. The best connector is lead on lead - assuming all are nice and clean when first used.
Garage - 1987 911 widebody |
'73 911T RoW (Project) '77 911S 2.7RS '76 914 2.0 Early911SReg #2945 Last edited by frankc; 03-08-2013 at 10:28 PM.. |
that makes perfect sense, my terminal has been acting up since I tampered with it when I added a relay, tried cleaning both the post and terminal but no joy.
when I move the piggy backed wire connections it results in better conductivity, I have an oem cable on it's way but want to make sure it is acutally the terminal that is failing.
avoid anything made in China. Bought some hi-end connectors and after 2 tows to the garage and a new battery, turns out the metal blend in the connectors was cheap and didn't have a proper voltage.
As previously noted, use same type of materials for terminals and battery posts.
Roger that
, Thanks again fellas!
Banned
Will there still be a galvanic reaction at the cable to terminal connector junction? The cables are copper and the terminal connector will be lead to match the battery terminal.
