-   -   Well, crud. What did I do now... (http://forums.pelicanparts.com/porsche-911-technical-forum/940955-well-crud-what-did-i-do-now.html)
walt83sc 12-31-2016 12:04 PM
After 3 years and 8 months of mostly procrastinating, I'm putting the engine back in my 1983 SC. Needless to say, after that amount of time, there's a lot of "discovery".
And I have a part left over. It's pretty thick, 3-4mm. It seems important. It has a rib welded to one side to make it stiffer.
And it was in with my Porsche parts, which are mostly separate from my MGB parts, my Ford 8N parts and my John Deere parts. But not always. :confused:
Can anyone identify this?
I've look through both of my Wayne books and the Bentley manual, no sign of it anywhere. The only stamping on it says 1130 VE. It had some surface rust, so it was somewhat exposed. I did put a coat of fresh paint on it. I still have quite a bit to bolt back on, like the rear bumper and oil lines... might be from there? I just don't want to have to take the engine back out, once I get it installed.
Thanks much!
http://forums.pelicanparts.com/uploa...1483213952.JPG
DRACO A5OG 12-31-2016 12:18 PM
Does it have a part number?
It really does not look like a Porsche part
Maybe ac mounting bracket?
ossiblue 12-31-2016 12:22 PM
Yes, AC compressor mounting bracket (actually, strut brace.)
http://i.ebayimg.com/00/s/MTAxMFgxNj...1X8DUJ/$_1.JPG
http://i.ebayimg.com/00/s/MTExMFgxNj...VX8C2W/$_1.JPG
http://www.autoparts.loc8apart.com/nav/auto-part-alt/Porsche/911/Air-Conditioning-and-Heating/compressors.php
walt83sc 12-31-2016 12:25 PM
Awesome, I guess it was in there somewhere. And now I can put it on the shelf next to the compressor...
Thanks much!
Canada Kev 12-31-2016 01:04 PM
And maybe label it... ;)
walt83sc 12-31-2016 02:27 PM
Yeah, labels would have been awesome. It was only supposed to take a couple months, though. :)
Making progress! The pile of parts is getting smaller. And my boxer can't wait for a ride.
http://forums.pelicanparts.com/uploa...1483222960.jpg
Jim2 12-31-2016 02:28 PM
Calling for a caption contest
zippy_gg 12-31-2016 04:08 PM
Somebody please correct me, but if your model year is anything like my 86 you should clock the fan strap so the bolt won't be on top or it will interfere with the engine lid and keep it from closing all the way.
Yeah, I did that :D. Just glad I didn't force anything or I would have dented the engine lid.
Mark Salvetti 12-31-2016 04:56 PM
I think he should be OK, my SC has the bolt dead center on top. There is a heater hose that goes up and over the fan shroud that is quite a bit taller.
It definitely would have been close if the AC condenser was still in place, but that looks to be on the shelf with the compressor.
However, I think the coil might hit the lid - it should go on the other way with the wire pointing down, and most of the body down below the clamp.
Mark
garment 12-31-2016 05:54 PM
+1.
Originally Posted by mark salvetti (Post 9415404)
i think he should be ok, my sc has the bolt dead center on top. There is a heater hose that goes up and over the fan shroud that is quite a bit taller.
It definitely would have been close if the ac condenser was still in place, but that looks to be on the shelf with the compressor.
However, i think the coil might hit the lid - it should go on the other way with the wire pointing down, and most of the body down below the clamp.
Mark
walt83sc 12-31-2016 09:33 PM
The coil is just sitting in the clamp to keep it from rolling around for now. Seems like when I put in the MSD ignition, I read that that coil needed to be installed with the cap pointing up, not down. I had it clamped to the rear engine support before I removed the engine. Still trying to decide where I'm going to mount it after the rebuild. Thanks for the tips though. You guys sure don't miss much!
-WE
blpetry 01-01-2017 04:16 AM
You need a bumper sticker... "Boxer on board", it would always be accurate even when the dog isn't with you!
Cairo94507 01-01-2017 06:04 AM
Good looking pup. :)
