Where does cruise control wiring enter engine compartment
Good morning,
Just for the sake of tinkering, I am considering reinstalling my cruise control system in my 84. The brain is present, and I have the tempostat and cable in a box. I cannot see the electrical cable that connects to the tempostat. I have a general idea where to look, but I don't see it. Does anyone have a picture or any guidance. Thanks, and Happy New Year, Dave |
Found it. There was a black cable with green and white wires under the engine sound pad. It seems to enter midway between the rear shock towers.
Unfortunately mine is missing the connector. Thanks, Dave |
Dave, here is pic of my 87. I have removed the heat tube & motor & installed block off plate. I don't really need that much heat in Texas. My cruise control cable was broken at the end-where it connects to throttle body. I've removed the entire system, you can see the vacuum block off & electrical connection. I've taped over the connection to keep debris out of the plug. Somewhere in that area is the connection for the heater fan. Hope that helps.
Terryhttp://forums.pelicanparts.com/uploa...1483374058.jpg |
Thanks, Terry. That confirms what I think i found.
Now to reinstall and troubleshoot the system. Best, Dave |
| All times are GMT -8. The time now is 01:47 PM. |
