Oil Temp & Pressure Gauge Question
I have a 1976 911 and the oil temperature gauge stopped working but the pressure reading works. Is there a way I can check the plugs or some way to check the gauge in order to locate the source of the problem?
Old 12-30-2016, 07:40 PM
Member 911 Anonymous
DRACO A5OG's Avatar
When you wrote, not working, is the temp gauge pegged up or just not moving from the bottom level?
'85 Carrera Targa
PCA/POC
Old 12-30-2016, 08:02 PM
well it does move whenever electricity is put to it, but after that it doesn't read anything.
Old 12-30-2016, 10:42 PM
DRACO A5OG's Avatar
So it moves a little off the bottom?
Do you have a IR reader to check the thermostat on the passenger side rear wheel well.
How long of a drive and what is the outside temps?
'85 Carrera Targa
PCA/POC
Old 12-30-2016, 10:50 PM
No IR reader. My driving has been anywhere from 55 degrees to 80 degrees maybe 45 minute joy ride trips.
I thought maybe there was a way to put an amp meter to the wires or just send the gauge somewhere.
Old 12-30-2016, 11:14 PM
DRACO A5OG's Avatar
Well, you could pull the gauge and place a volt meter to the wires and after 45 minutes, see if the voltage changes, this way you can verify if the sensor is bad or the gauge or if you a have Pelican near by that will help you out, you can swap their gauge into you car and verify that way too.
'85 Carrera Targa
PCA/POC
Old 12-30-2016, 11:24 PM
Does anyone know where to find the proper wiring configuration? I want to double check that these are correct.
I really have no idea what I'm doing with the multimeter. I'm pretty sure I'm checking for ohms, but I don't really know how to start i.e. where to put the ground lead.
Old 01-03-2017, 03:23 PM
