| ASE Master Tech - 35 yrs |  lower cam cover corner leak - at wit's end
			i have a seemingly incurable leak at only the lower rear corner of one cover (911 orientation) - on a 3.2  the covers are brand new, and pass the "flat bench fine sandpaper" test & draw-file tests - no warps - appears to be weeping out at the corner stud & past the nut/washer, but appearances aren't everything, eh? - this is mostly a problem when the car sits long time & the oil tank leaks down into the engine - i actually don't notice a problem when driven frequently - have read a dozen or more threads on this cover leak issue, and tried all the usual ideas, - no joy  y'all have any more ideas?  p.s. - - re: silicon "reusable" gskts - are they really? - i find that mine compress - always less thick after use than original out of box
				__________________ "... I am German, and if it has no logic it's meaningless." 914 & 914-6 parts FS 03-2021  www.tinyurl.com/2pmpmv8y 911 parts FS 2022  https://tinyurl.com/911-Parts-FS-LCM Last edited by larrym; 02-17-2017 at 09:29 AM.. Reason: resolved | ||
|  01-12-2017, 08:00 PM |
| El Duderino |
			Other than using the 'thick' valve cover gaskets that John Walker recommends and barring some other simple solution, what about the Rothsport oil inlet check valve? That would keep oil leaking from the tank to the engine. Not a cheap fix but... Pelican carries it by the way. I tried the same silicon ones. I have another set of the good old fashioned valve cover gaskets sitting on the shelf for the next oil change.
				__________________ There are those who call me... Tim '83 911 SC 3.0 coupe (NA) You can't buy happiness, but you can buy car parts which is kind of the same thing. Last edited by tirwin; 01-12-2017 at 08:11 PM.. | ||
|  01-12-2017, 08:09 PM |
| Registered Join Date: Nov 2013 Location: NW NJ
			The silicon gaskets have a much lower torque spec than the paper ones.  If I recall correctly, it was 45 inch/lbs. but it was in the directions that came with them.  No leaks for me once I switched to silicone.
				__________________ 1988 930 Venetian Blue | ||
|  01-12-2017, 08:15 PM |
| Member 911 Anonymous |
			+1 the silicon has lower torque range I use the lower value recommended and take a second pass to insure all nuts are tight to silicon manufacturer specs | ||
|  01-12-2017, 08:32 PM |
| Registered Minimalist |
			Had the same problem. I sanded my covers a second time and switched from the silicone back to cheap paper gaskets. This time I was uber careful when torquing the nuts down. That has stopped the leak there. I think when I had the silicon I over torqued and when they leaked, i went back and tried to tighten again which made them leak even more.
				__________________ Duane / IG: @duanewik / Youtube Channel: Wik's Garage Check out my 75 and 77 911S build threads | ||
|  01-13-2017, 05:22 AM |
			thanks all  - resolved  pulled it off & replaced with a different cover, re-using the old Si gskt - meanwhile - where does one get the " 'thick' gaskets that John Walker recommends" - is it this? Weltmeister® 911 Valve Cover Gasket, Part #65-220965-1 ?? - or these from Pelican? http://www.pelicanparts.com/catalog/SuperCat/0826/POR_0826_BASFLT_pg3.htm#item13 - or these RG-911LATE-4 http://www.realgaskets.com/index.htm or are all above the same product from one source ???? - see http://www.early911sregistry.org/forums/showthread.php?36002-Silicone-Valve-Cover-Gaskets-Cheaper! some ANSWERS: - http://rennlist.com/forums/911-forum/214179-80-911-sc-valve-cover-oil-leaks-fixed-after-3years.html - Valve Cover Gaskets - Standard vs Silicone? .- Leaking Silicone Exhaust Cover Gaskets .. What to do Now? - ,
				__________________ "... I am German, and if it has no logic it's meaningless." 914 & 914-6 parts FS 03-2021  www.tinyurl.com/2pmpmv8y 911 parts FS 2022  https://tinyurl.com/911-Parts-FS-LCM Last edited by larrym; 02-17-2017 at 09:33 AM.. | ||
|  01-15-2017, 09:36 PM |
| Straight shooter |
			Consider swapping to the Hargett billet covers which feature the modern gasket type?  These are much more service friendly and reusable.  I would also inspect the cam tower for leaks above the gasket line. There are studs that thread entriely through the casting in places with atmosphere on one side and oil bath on the other. Sent from my SM-T580 using Tapatalk
				__________________ “Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.” ― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values | ||
|  01-19-2017, 07:09 AM |
| Registered Join Date: Oct 2006 Location: MYR S.C.
			you have over tightened the gaskets.  I just hand tighten mine and they are very very lose. if you think they are tight enough, you over tightened them. they should NOT squeeze out past the valve cover. your leak is probably the cam line on top of the engine, I thought my leak was the lower stud at the corner for #4. it was the cam line. there are 3 washers on there. replace them. the reusable gaskets are awesome.
				__________________ 86 930 94kmiles [_  _] RUNNING:[__] NOT RUNNING: ____77 911S widebody: SOLD 88 BMW 325is 200K+ SOLD 03 BMW 330CI 220K:: [_  _] RUNNING: [__] NOT RUNNING: 01 suburban 330K:: [_  _] RUNNING: [__] NOT RUNNING: RACE CAR:: sold | ||
|  01-19-2017, 09:46 AM |
