-   -   Help needed removing the shifter pivot cage (http://forums.pelicanparts.com/porsche-911-technical-forum/941546-help-needed-removing-shifter-pivot-cage.html)
Alex599 01-05-2017 05:43 PM
Howdy guys,
I can't seem to be able to remove this Allen bolt to free the pivot cage. Am I missing something? I tried heating it up and torquing pretty hard without success. Any ideas?
http://forums.pelicanparts.com/uploa...1483670514.JPG
Thanks,
Alex
Elombard 01-05-2017 06:03 PM
Yeah I broke my tower trying to get it loose.
be careful.
jrbennett 01-05-2017 07:02 PM
I find it easier to loosen the lock nut with the tower still attached to the car, then the bolt just turns out freely.
dicklague 01-05-2017 07:08 PM
repeated liquid wrench and tighten it then more lubricant and keep at it .....carefully.
Alex599 01-05-2017 09:40 PM
Soaking overnight. Let's hope it loosened up.
Thanks all,
Alex
Ayles 01-05-2017 09:48 PM
Put it back in the car so you can get some leverage on the large nut. Also worth noting that in my first go at this job I messed up the threaded pin and found out it's virtually impossible to find a replacement on its own. A pelican came to the rescue with a complete shifter assembly.
psychoideas 01-05-2017 10:39 PM
This!
It's a lock nut doing exactly it's job.:D
Alex599 01-06-2017 04:09 PM
I tried clamping the tower down after a night of soaking in penetrant. No luck. How much can I heat this part? Is it possible to overheat it with a blow torch?
Also, I don't have to unscrew the brass nut right? It only acts as a "depth locker" for the Allen bolt right? The way the threads go, I don't see the brass nut impede the release of the black Allen bolt. Having said that, I've been known to be wrong!
Thanks,
Alex
psychoideas 01-06-2017 04:17 PM
Thanks,
Alex
Wrong.
undo the "Brass" nut first. It's what's locking the screw in.
psychoideas 01-06-2017 04:20 PM
The allen bolt is theaded into the housing. and the Nut is trying to pull the tread out of the housing and s such putting pressure on the allen bolt and 'Locking' it into position.
Undo the nut first while holding the allen bolt still with an allen key
Alex599 01-06-2017 04:46 PM
Ok, thanks. Having said that, I tried the nut, it doesn't budge. I'll try more penetrant. Thanks guys.
psychoideas 01-06-2017 04:52 PM
Yes it's a pain. there's no room to get a socket or ring spanner in there. just have to use a good open ender with brute force while holding the housing. I remember mine was tight.
Ayles 01-06-2017 04:54 PM
Before you waste anymore of your time, why not bolt the base back into the car and unbolt the lock nut with a socket. It will make your life easy. No chemicals, no flames and no frustration.
Ayles 01-06-2017 05:00 PM
22mm 1/2inch drive fits perfectly.
http://forums.pelicanparts.com/uploa...1483754417.jpg
Alex599 01-06-2017 05:18 PM
I'm on it!
Alex599 01-06-2017 05:23 PM
I assumed a socket wouldn't fit in there.
Alex's learnt lesson of the day: Never assume!
Thanks all!http://forums.pelicanparts.com/uploa...1483755821.JPG
psychoideas 01-06-2017 05:36 PM
did you get it?
Ayles 01-06-2017 05:38 PM
Glad it worked out!!
Alex599 01-06-2017 10:22 PM
Originally Posted by psychoideas (Post 9423079)
did you get it?
I did, thanks. I clamped the tower to my workbench and used a 22 mill socket and barker bar.
psychoideas 01-06-2017 11:15 PM
Awesome!
What are you doing? a refurb or wevo type replacement?
Alex599 01-07-2017 08:32 AM
Originally Posted by psychoideas (Post 9423265)
Awesome!
I'm installing the Porsche short shifter kit I got here on the bird. I'm really happy with myself as I barely have any mechanical experience. (Changed oil and recently ventured in replacing my F-150's pads). According to Wayne I should now be "comfortable working on more complex assemblies such as top ends, clutches or exhaust replacements". I love working on the 911! The only limit to all the projects I want to do is cashola. One project at a time. Next up is replacing the passenger window switch on the driver's side. Keep your eyes opened for that one on another thread.
Alex
psychoideas 01-07-2017 02:01 PM
Well done Alex. You will get great satisfaction working on your own cars. You'll get several major blunders as well, but we've all had them.
Look forward to seeing your work.
Cheers
Frank
