Cruise control cable compatibility
Hi Guys,
I was looking to buy a new cruise control cable for my 84. The only one I find on our host is for 81-83. Different part numbers, but they look the same basically. Dose anyone know if the 81-83 cable will fit 84-86 911's? Thanks, Dave
Dave McKenzie 1984 Carrera 3.2 1984 928S Automatic 2001 996TT |
the cable on my 85 connector at the TB broke off.
I replace with a guitar string, keeping the outer part of the assembly.
Bob Cox 78 930 clone project car. 87 924S resurrect at some point. 84 928S, Ruby Red linen/brown interior - sold ![]() 86 944 turbo my new DE/track car - sold
The Carrera models started in 1984 of course. The end is fixed in place and you screw it into the throttle assembly. To my knowledge they are not available new. I looked around a lot. My cable snapped off and I have never found the end piece. It is in the engine compartment somewhere.
Finally I found a used one. You can check on Ebay or here on Pelican in the for sale - used parts section. To replace the entire cable you have to remove the three screws on the front of the vacuum module behind the heater fan. It is a little trick getting the cable off of the vacuum module but easy to figure out. Most likely the replacement used cable will have a brittle clip that holds the cable in position. Use two or three zip ties to hold it in place. If you find a source of new ones please let me know.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Thanks. I am using a used cable, and it needs some zip ties to reinforce it. Was just looking for a new, intact alternative.
Dave
Btw the cable I'm using did not have enough travel to allow full movement of the throttle back to idle. I had to cut out an inch of the outer sheath and reglue.
Dave
