Paul Valcourt's Avatar
Drilling out exhaust studs, yahoo
I decided it was time to fix my heat and all the oil leaks so I removed my exhaust and broke a few studs in the process. I then dropped the engine/trans, power washed then separated them. The job of removing the broken studs and replacing all the other studs looked like it would be somthing I would screw up and end up replacing my heads. I contacted a local engine machine shop and told him I had an air cooled motor with broken exhaust studs, he said to dismantle it and bring the heads in. Then asked what type of motor, when he heard Porsche the response was don't bother, wouldn't touch it for anything. Pretty well all the other shops responded the same and my anxiety was growing. I grabbed the bull by the horns and set to drill them out myself and surprisingly they came out pretty easy after I took the time to ensure the bit was centered and staight. The other studs came out easy after I mig welded a nut to them, now the other task of fixing oil leaks and upgrading tensioners doesn't look too bad.
Now its beer time before the next task.
75 targa 2.7
Lean and green
Old 01-15-2003, 05:09 PM
job well done. The replacement studs are like .78 cents each. How ironic.
Good job!
Chris
Old 01-15-2003, 07:05 PM
Congrats! You must "living right!" Cheers, Jim
Old 01-15-2003, 07:37 PM
VW is what they expect. The head is cheap.
Porsche heads are much much more expensive and they all need to match up, so you actually have to bring in all 6 heads. Then, top that off, Porsche owners tend to be more picky and therefore ... a $50 job can turn into a $5000 repair job for them. A total losing proposition.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 01-15-2003, 08:39 PM
