-   -   Center console. What's this plug? (http://forums.pelicanparts.com/porsche-911-technical-forum/941924-center-console-whats-plug.html)
Alex599 01-09-2017 02:40 PM
Hi guys, I'm just about to reinstall my center console and was wondering what this flat white plug is. It is not connected.
While I'm at it, any ideas how to screw in the rear of the console (pointy little tab). I can't for the life of me figure out how to do it with he carpet in place.
Thanks,
Alex
http://forums.pelicanparts.com/uploa...1484001552.JPG
DRACO A5OG 01-09-2017 02:44 PM
Seat Belt Warning Light or Seat Warmer.
Arne2 01-09-2017 02:50 PM
On my '84 the flat white one goes to the stereo fader switch between the A/C controls. Or it would have, if the switch were still present and in use.
Alex599 01-09-2017 03:07 PM
Ah ha! You just solved two mysteries! I was wondering what that dimmer was between the two AC knobs. I have an aftermarket stereo now so I'll just tuck that baby back in.
Thanks again Arne!
86 911 Targa 01-09-2017 03:21 PM
Console screw.
After you have the two forward screws attached,
you will need some type of pick or sharp pointed
tool to find the screw hole under the carpet.
Then tuck the tab under the carpet & attach
with the screw.
That's what I did.
Best,
Gerry
Alex599 01-09-2017 03:29 PM
with the screw.
That's what I did.
Best,
Gerry
Ok, I'll try that. Thanks Gerry
