Randy Webb's Avatar
fan pulley on engine - single drive
I'm modifying a 1986 3.2L engine for my '73. The fan pulley on the engine cranshaft (not the Mg blower fan) has a double pulley on it. One drive for a blet to the A/C or smog pump I guess, but I have neither. Is there a single drive fan pulley that I can get to replace the double drive one? Does anyone know the part number? I want to make sure it has the same diameter, etc. as the stock one. Thanks!
Old 01-15-2003, 12:30 PM
stormcrow's Avatar
Not sure if your's will be the same as mine, but if you go to Napa or PeP Boys, ask for a 28.5 inch belt (that's the length of the belt). Try that size and see if it works.
If it is too small, go to the next size 29.0 and it should work. Take one of the old belts with you to match up the width and depth of the belt, but not the length.
"A Porsche does more then just go fast in a straight line"
SteveKJR
Proud Owner of a 78 911 SC Targa
Old 01-15-2003, 06:12 PM
Paul Thomas's Avatar
I think he wants the pulley, not the belt.
Paul
My ignition is retarded.
Old 01-15-2003, 06:14 PM
stormcrow's Avatar
Sorry about that I had my mind on the belt.
SteveKJR
Old 01-15-2003, 06:47 PM
Senior Member
Doug Zielke's Avatar
The single pulley part # is: 930 102 028 08
They are horrifically priced at the Stealership, however.
BTW.....if anyone has a *single* pulley for a 1980-1982 SC (p# 930 102 128 04) that they would sell, please contact me.
'81 SC Coupe "Blue Bomber"
"Keep your eyes on the road, and your hands upon the wheel."- J.D.M.
Old 01-15-2003, 07:13 PM
