oil loss / valve covers
Brains - please let me know what kind of mess I'm looking at when removing the upper & lower valve covers. I don't want to drain the oil before (just changed the oil).
Thanks.
Old 01-11-2017, 02:22 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Do not worry, it will be very minimal maybe 1/4-1/2 a quart. If you do not have to turn the crank then raise one side at a time and you will lose even less.
I removed the tin to check my work and on the rockers. Did not drain the oil
'85 Carrera Targa
PCA/POC
Old 01-11-2017, 02:25 PM
jack up the side of the car you're working on for the lowers and that should minimize the oil lost as well as keep it less messy!
'79 930 turbo RoW - Oak Green Metallic - k27-7200 Raptor - Kokeln Intercooler - RarlyL8 headers/muffler - Tial 46mm - 964 turbo WuR - Rebel racing bushings front/rear - ER Monoballs front/rear - ER adjustable spring plates - 29/23mm TBs - Vons level 2 - Raised spindles w/weld on racing bump steer knuckle -Wevo engine mounts - Rebel racing transmission mounts - Ruf speelines 17x9-10 - Classic retrofit electric A/C
Old 01-11-2017, 03:27 PM
Jim,
I can help you with this. Let me know.
Dana
Old 01-11-2017, 07:27 PM
Place a sheet of aluminum foil over the heat exchangers before you unbolt the lower valve covers. Keeps the HE's tidy when I'm adjusting the valves. Should be especially helpful if the oil's not being drained.
'88 Carrera
Guards Red
'70 VW Beetle
Yukon Yellow
Old 01-12-2017, 08:13 AM
safe's Avatar
It depends on how long since the engine has been runned. Oil migrates from the tank to the case, so start the engine before removing the lower covers. 20-30 seconds is enough.
Old 01-12-2017, 08:27 AM
DRACO A5OG's Avatar
Good Idea, but do not do this if you plan to do a valve adjustment, car must be cold for a valve adjust.
'85 Carrera Targa
PCA/POC
Old 01-12-2017, 08:42 AM
Thank you!
The PP board is truly a wonderful resource for me. Thank you all for the information and advice.
Old 01-12-2017, 10:34 AM
Oil loss
If you have oil loss from the valve covers why not just try to tighten them up to spec first? Sometimes they will work themselves loose. Happened to me months after a valve adjustment. Tightened them up and no leak since!!! Easy stuff first.
Old 01-12-2017, 06:58 PM
Paper or rubber gaskets. From experience what do you prefer. I will be changing my lower valve covers to Turbo valve covers.
Old 01-12-2017, 08:10 PM
