-   -   Voltage regulator questions (http://forums.pelicanparts.com/porsche-911-technical-forum/942351-voltage-regulator-questions.html)
Trackrash 01-13-2017 08:12 PM
OK, I decided to replace my original mechanical voltage regulator with a new solid state unit. The problem is the new one has NO LABELING for the electrical connections. Which wire goes where?
http://forums.pelicanparts.com/uploa...1484367011.jpg
The next question is do I need the capacitors that the old unit has?
http://forums.pelicanparts.com/uploa...1484367096.jpg
Thanks,
gerakroo 01-13-2017 10:52 PM
The brown wire goes on the middle one.
The red wire coming from the upper condensator goes to the left.
The red wire coming from the lower condensator goes to the right.
Trackrash 01-14-2017 11:33 AM
I'm still want to confirm three things.
Is this the correct regulator to match with my '71 SEV Motorola alternator?
Can I eliminate the capacitors that are used with the original regulator? Are they still needed?
Is this picture showing the correct labeling of the regulator's terminals?
http://forums.pelicanparts.com/uploa...1484422424.jpg
