-   -   Alternator Light On after engine Off? Help! (http://forums.pelicanparts.com/porsche-911-technical-forum/942752-alternator-light-after-engine-off-help.html)
ivanuf 01-17-2017 04:04 PM
I turn on the engine the alternator light goes off and all is working fine. When I shut the engine off the alternator light will come on and stay on (key or no key). Any clues on how to troubleshoot this? Engine running, light off - Engine off, light on???
uwanna 01-17-2017 04:36 PM
Could be a shorted diode in the alternator.
Jdub 01-17-2017 04:43 PM
Check your battery ground and be sure the terminals are also clean and tight. If unsure, fully charge your battery then see if the light continues to stay on.
This is a cheap fix that actually worked for me - no guarantees.
ivanuf 01-17-2017 04:49 PM
I will leave the battery tender connected tonight and see what happens before removing the alternator
timmy2 01-17-2017 05:23 PM
Remote VR acting up?
30westrob 01-17-2017 05:23 PM
I have seen a shorted positive diode cause your symptoms. Rob
