copper's Avatar
Valve Cover Gaskets - Standard vs Silicone?
Looking for opinions on theses gasket sets.
A standard gasket set with uppers, lowers, sump and all nylocks and washers is $19
A set of Silicone gaskets alone, without the sump gasket or nylocks is $47
"Apparently" these silicone ones can be used over and over and over...
Any members with experience with them?
Jim
Jim Dean LL.B. - London, Ont, Canada.
1969 911T "Blood Orange" Euro (Brought over from Germany in 86)
Engine and brake system rebuilds 2006 & 2007
"Oversteer scares passengers, understeer scares drivers."
Old 09-23-2004, 10:58 PM
copper's Avatar
Bump
Old 09-24-2004, 02:11 AM
I jst took my green ones off the lowers and both of them ripped.
I imagine I could have been more careful but why bother?
these were on there less than a year, I took off the covers for a rocker problem.
I Bought the kit with regular (black) upper ones, and green (lower) ones, plus hardware, I dont remmeber 47$ though
Old 09-24-2004, 02:32 AM
jluetjen's Avatar
I've got the silicons and they work great and are leak free as long as they are installed correctly. The correct technique is that the nylocks need to be slightly more then finger snug. You want to lightly pinch the gasket between the covers and the cam towers. The absolute wrong way to install them is to crush the gaskets like you would a paper gasket. The correct torque on the nylocks is in-lbs or maybe even inch-oz. Anything measureable on a normal torque wrench is way too much.
Do a search on this BBS on "Silicon gasket".
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 09-24-2004, 02:34 AM
Unregistered
sammyg2's Avatar
I have em and like em.
They have to be installed dry, no oil or sealant.
The torque is about half of the OEM gaskets. Overtorquing them will cause leaks.
Old 09-24-2004, 06:12 AM
derek murray's Avatar
I have silicon gaskets on my lowers... they eliminated 90% of the oil leaking from my OE valve covers... and ditto what John said.
'70 911S 1002938
'70 Ducati Mark 3D 350
Old 09-24-2004, 06:20 AM
djmcmath's Avatar
Hmmm ... I torqued the living snot out of mine, then -- prolly 10-15ft-lbs. No leaks, though.
Dan
'86 911 (RIP March '05)
'17 Subaru CrossTrek
'99 911 (Adopt an unloved 996 from your local shelter today!)
Old 09-24-2004, 07:45 AM
73911guy's Avatar
I tried the silicone gaskets and despite using a brand new Snap On torque wrench (in inch pounds) at the torque (specified on the package the silicone gaskets came in) found that they leaked just like the old plain black ones.
After installing gaskets with the silicone bead on them and torquing to the factory specs mine don't leak at all. Same with my co-worker on his 930.
Don't spend the money on the silicone ones - just make sure you get the gaskets with the silicone bead - not the black ones, not the green ones, just the ones with the silicone bead. They're not cheap and you have to ask questions wehn you order them to make sure you get what you want but they are worth the effort.
Jim
73 911
Old 09-24-2004, 09:58 AM
Unregistered
sammyg2's Avatar
IIRC the instruction in the package recommended something like 3 ft. lbs of torque.
Old 09-24-2004, 09:59 AM
scottb's Avatar
I use silicone gaskets on the helicopter. Paper gaskets leaked terribly...the silicone gaskets are dry as a bone. Don't overtighten them or they'll squeeze out and leak. Snug is good enough.
1984 Targa
Old 09-24-2004, 12:04 PM
Zeke's Avatar
Jim
73 911
I think if you place your valve covers on a piece of plate glass (not tempered) and run a .003 feeler gauge around the perimeter, you will find your covers are warped. You can sand them on the same piece of glass until the feeler gauge won't go under the edge. At that point, I bet you could use any kind of gasket.
I've been doing this to carbs for years because always some nimrod has over-torqued the screws to try to stop gas leaks. Guess what? It just gets worse. They never leak when the metal surfaces mate properly.
Old 09-24-2004, 12:33 PM
Senior Member
Jdub's Avatar
Get the red "Real" brand of silicone gasket. They are quite good.
John
'78 Targa in Minerva Blue
Old 09-24-2004, 01:09 PM
73911guy's Avatar
1. The silicone gaskets I bought were from the "Real Gasket Co. " The drips they made really made my new SSI's look fabulous. Hah.
2. The valve covers were brand new Turbo lower covers from PCNA. Didn't check to see if they were warped or not.
3. Everything stopped leaking when I went to the gaskets with the silicone bead. Don't care if the covers are warped or not, I'm using cheaper parts and not having any leaks.
4. I returned the gaskets to the supplier and got a new set under their "lifetime warranty". Hope the guy I sold them to had as much good luck as you folks did.
My only advise is to save your money.
Jim
Old 09-24-2004, 04:42 PM
I had the silicone gaskets since day one/after my 1st oil change years and years ago. Bone dry......forever and ever.
I use SK and/or Craftsman torque wrench....40 inch.
Highly, highly, highly recommend them.
And those nylocks, I've reused mine forever with no problem. (sssssh, keep quiet....the 'reuse suggestion' came from the guy over the counter.
Old 09-24-2004, 11:00 PM
khamul02's Avatar
any comments on Weltmeister Silicone Valve Cover Gaskets?
Tom Hutchinson
80 Targa / 81 Coupe / 71 Targa (in Porsche heaven)
My Garage Build: https://youtu.be/H0n_NwEQVbs
"If one does not fail at times, then one has not challenged himself." Ferdinand Porsche
Old 04-25-2006, 07:08 PM
ASE Master Tech - 35 yrs
larrym's Avatar
Question
are all the red Si gskts offered to us the same quality & thickness - or not?
cross linking to this -
lower cam cover corner leak - at wit's end
"... I am German, and if it has no logic it's meaningless."
914 & 914-6 parts FS 03-2021 www.tinyurl.com/2pmpmv8y
911 parts FS 2022 https://tinyurl.com/911-Parts-FS-LCM
Old 01-15-2017, 09:58 PM
KNS KNS is offline
I thought there was only one red silicone gasket kit. I purchased a set years ago and have used them over and over. Nuts are just snug tight by hand - never any leaks.
Kurt
Old 01-16-2017, 03:47 AM
You can't tighten the nuts. What's wrong with this picture?
206 637 4071
Old 01-16-2017, 05:24 AM
al lkosmal's Avatar
I use the gaskets with the silicone bead.............you can tighten them and they don't leak.
regards,
al
RGruppe #669
http://www.x-faktory.com/
Old 01-16-2017, 06:59 AM
gtc gtc is offline
abides.
gtc's Avatar
I've never had andy leaks with either the silicone gaskets or the paper gaskets.
I must be doing something wrong.
Graham
1984 Carrera Targa
Old 01-16-2017, 07:48 AM
