Tips for replacing oil pressure switch?
I'm 99% certain that the source of my car's slow oil leak is the oil pressure switch. The mechanic who did the PPI told me it leaked a little at the "oil pressure" something. I thought he had said "sender," but that is visibly dry. The drip is coming from the back of the engine, and today I poked my borescope back there and there is definitely fresh oil in the area, seemingly concentrated around the switch. Attached is a grainy picture of the area...
I've heard that the switch can be replaced, with liberal contortions and cursing, without even a partial drop of the engine. I'd really rather not have to drain the oil and take on the partial drop to do this. Can I get away with just removing the air box and, maybe, the AFM? I've read that some people put some Loctite 574 flange sealant on the switch when they replace it, but to me it seems like that wouldn't seal against the pressure of the oil system there. Thoughts? Thanks in advance ![]()
1988 911 coupe 1976 Vespa Rally 2015 Honda HR-V |
911SC Tinkerer
I'm pretty sure there a lot of people here who will tell you to drop the engine and address the "triangle of death" and the other while you are in there stuff while you're at it.
Might be easier than you think. -Steve
-'83 911SC Coupe SSIs, Dansk GT3, EFI ITB, Instagram: @ Zinnmetallic_sc |
Rescuer of old cars
Can be done on a 3.2 without the partial drop. I did it. Like you said, pull the airbox and AFM. Still hard to see and get to, trained fingers are very helpful.
I'd recommend doing the breather gasket and oil thermostat o-ring at the same time. On my '84 both of those items were quite crispy. If you do them, be careful when removing so as not to drop pieces of them into the motor. Also take a good look at your breather hoses (the big hoses going to the oil filler and airbox). Mine were getting badly weather checked.
2018 718 Cayman 2.0 Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0 |
Wer bremst verliert
Whatever you do, the best tip I can offer is to clean everything 100%. You dont want any crusties falling in the sensor fitting.
2007 911 Turbo - Not a toy 1985 911 Cab - Wife's toy 1982 911 3.2 Indiash Rot Track Supercharged track toy 1978 911 3.0 Lichtbau toy "Gretchen" 1971 911 Targa S backroad toy |
88 911, It's easier to remove the airflow sensor, air cleaner and if necessary, pull the right bank if the injection, but that's a lot more complicated than just the sensor and air cleaner.
Bruce |
RETIRED
The TOD is a traditional repair/rite of passage item for the air cooled crowd. Time to join the club, bud....someone should make a tee shirt documenting passage like cross the international date line or the equator.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
I started to pull the air box and AFM tonight. I unbolted them from their brackets and popped the AFM off the air hose, but I can't figure out how to move the assembly to get it completely out. I had to head in for the night. What's the trick?
Did you remove the nut inside the airbox holding it to the manifold? See the rubber buffer in the front that you removed the nut off of? There is another one inside the airbox.
1987 911 Carrera coupe - Guards Red 2010 997.2 C4S 6-Speed 2005 Mini Cooper Convertible (R52) - Wife's car 1977 VW Bay Window Camper Bus |
Oops, no! When someone earlier said to remove it as one assembly I assumed I didn't need to open it. Thanks!
Aha, then that's your problem. Just unlatch the right side of the airbox and remove it, pull out the filter, and you should be able to feel the nut on the bottom of the part of the airbox still attached to the manifold. It's the same size as the front one (M10?). You'll have to lift the box up to get it over the two studs while at the same time pulling it to the right to get the AFM out of the rubber elbow. Just a little fiddly. You'll do fine. Oops - I see you've already freed it from the elbow. You're almost home.
I did the full triangle without the partial drop.
My best tip is to raise the rear of the car on jackstands. It's a much more comfortable angle to lean over the engine for the work. Couple other things: the sending unit had a very low torque spec if I remember right, basically finger tight. My 3.2 had a bracket I think for hoisting the engine that had to be loosened to get the breather cover off. Double check all the vacuum hose connections when you're done. I missed one and had a hard time it tracking down after the fact. |
Damn, why didn't anyone tell me the air box has clips at the back?! That was confusing, Bentley to the rescue though. Finally got everything removed, put the borescope back there again, and confirmed for sure that the switch is the source of the leak. Hopefully I'll get it replaced this weekend.
Dial 911
Like Joe Bob referred to...'Its a pig of a job' and it just takes lots of patience... Just a suggestion - If you would like a 'safety alert light', purchase the sensor with the twin terminals. The stock one is only wired for oil pressure.
BTW, the fun starts when you 'try to' put the bottom rear air filter box clip back on. Make sure to take the oil filter off, and make up a wire hook so as to pull the clip shut...Unless you have very tiny hands like 'the donald' that is.
Cheers! “Simplicity is the ultimate sophistication.” Leonardo Da Vinci Last edited by A horse with no name; 12-29-2016 at 08:54 PM.. |
Switch replaced, I just need to get the air box and AFM back in. Hopefully this week. To be honest, actually working back there where the sensor is was no big deal. With my head in the right spot I could see it, and my $20 Android borescope camera helped me clean up the surrounding area. A deep socket at 6" extension was all it took to get it out, and my small torque wrench had no problem tightening the new one.
The old switch looks like it was leaking from the red plastic part of the housing, not actually at the metal surface where the crush washer is. My replacement is a different brand, from Pelican, hopefully better quality.
Dial 911
Hi...On your heading - Quote: "Tips for replacing oil pressure switch? my info seems not to have been applicable to you as I thought you were replacing the engine oil temp sender, including the oil presure sending unit.
Our car is a '86 and I see that yours is a '88...As a matter of interest, what "oil pressure switch" did you end up replacing?.. I ask, as I was not aware that there was a need for second one - Thanks in advance!
Cheers! “Simplicity is the ultimate sophistication.” Leonardo Da Vinci |
Dial 911
Hi...Thanks for your reply; unfortunately I still cant' seem to picture it.
Re back and front - Quote: "That's at the very back of the engine/car, near the fan." When I open the engine hood, I consider this to be the front of the motor where there is both a oil temp sensor, including the oil pressure sending unit... 'Back,' to me that is, is towards the transmission. If you still have it, would you mind posting the part #? - Again... Thanks in advance!
It's nearer the transmission, above the bell housing, next to the breather and the thermostat. The PN is 911-606-230-00-OEM.
Dial 911
Thanks 'autojack' for informing me of 'where' and 'what' the sensor/switch did that you replaced!..I never knew that our car even had one. I have replaced the two on the front of the engine for the oil temp and pressure; I likely should now replace this one also ay. I wonder if there is a way of testing them?.. (I don't have any oil leaks whatsoever)
Cheers! “Simplicity is the ultimate sophistication.” Leonardo Da Vinci Last edited by A horse with no name; 01-05-2017 at 11:56 PM.. |
