LinkBack Thread Tools Rating: Thread Rating: 2 votes, 1.00 average.
sugarwood's Avatar
Engine drop in just one minute?
Correction, he said 30 seconds!
This post was regarding a better way to change 930 spark plugs (partial engine drop)
Originally Posted by Norm K View Post
Yowsa! Let me suggest that you're going about it all wrong. It takes maybe two minutes per side to remove the rear engine mounts and all of 30 seconds to drop the engine about six inches to expose the plugs inside the wheel wells. Plugs out and in a a couple of minutes each, a minute or so to raise the engine back into position and 2-5 minutes (depending on how deft you are at aligning the mounts while holding the large washers in place and starting the threads) per side to re-install the mounts. I could change the plugs -- on a twin-plug 930 -- in an hour from the time I walked into the garage until the last tool was cleaned and put away.
_
Can you slowly tell the n00bs how you can do a partial engine drop in just one minute?
Is this how it's done?
1) Support engine from below with floor jack.
2) Remove both motor mounts on the corners of the engine bay. (see pic)
3) Lower jack.
How far can you go before ripping something?
1986 Bosch Icon Wipers coupe.
Old 01-18-2017, 02:45 PM
I don't believe the engine will move very far without also removing the tranny bolts as well. This is typically referred to as partial engine drop, and should get you about 6 inches. Just be careful that the jack doesn't go down too quickly as you could damage wires or hoses if you aren't careful.
David Yerkes
1987 911 Targa - GP White
Old 01-18-2017, 02:58 PM
our young tech left the limiting washers off the top of the engine mounts.
on a recent install on a 71t
he called on the test drive, after he went over a dip
when we arrived, the new heat exchangers were dragging on the pavement.
engine mounts, trans mounts, speedo cable, shifter coupler, lower valance
muffler and the exchangers were tweaked
esp the exchangers
Old 01-18-2017, 04:50 PM
Work in Progress
Rich76_911s's Avatar
You have the procedure exactly right. You don't need to undo the transmission bolts.
You can lower it 4 inches easily and probably more. For the first time just do it slowly an inch at a time and check that nothing is getting caught.
Easy peazy lemon squeezie as my 5 year old says.
"The reason most people give up is because they look at how far they have to go, not how far they have come." -Bruce Anderson via FB
-Marine Blue '87 930
Old 01-18-2017, 05:20 PM
Send a message via Skype™ to kyngfish
Two questions
What, aside from spark plugs is made easier with a partial drop?
Also. When I did my motor mounts, rethrewding the bolts was really challenging. What's the trick.
1986 Carrera Coupe - 1987 W124 300E - 1999 Land Cruiser 100 - 2021 GLA250
Old 01-18-2017, 05:41 PM
The trick is to realize that the engine mount brace is flexible and bends with some coaxing.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 01-18-2017, 05:44 PM
Platinum Member
dad911's Avatar
As I recall some are not threaded and use a bolt (earlier cars?)
The more you do it, the easier it is......
Old 01-18-2017, 05:46 PM
carwash's Avatar
Yes earlier cars are nut and bolt.... not sure when the switch to a threaded boss happened.
1968 912 - widebody - 3.2 - 915 - endless build
1980 911 - targa - barnfind nightmare - gone
1985 911 - targa - barnfind nightmare - gone
2017 991 - C4S - summer daily - for sale
IG - therealcarwash
Old 01-18-2017, 07:28 PM
universeman's Avatar
Put a knee on the bumper with your weight to push the car down while you thread the bolts. You're pushing against the shock absorbers which are lifting the car.
Old 01-19-2017, 05:04 AM
A guy did that on a 930 at the dealer I worked at in the 70s, damaged a fuel line and had a fire.
206 637 4071
Old 01-19-2017, 10:50 AM
Crotchety Old Bastard
RarlyL8's Avatar
I use this method to do valve adjustments. Be VERY CAREFUL not to stretch or bend anything! Fuel lines throttle loop and wiring harness are all bound to the chassis, among other things. Axles also only move on engine side and tend to hang on things.
Old 01-19-2017, 11:07 AM
sugarwood's Avatar
Weird to think the entire engine is held up by those 2 bolts
Old 01-19-2017, 02:22 PM
4 bolts..... and how many more do you need?
Old 01-19-2017, 02:29 PM
Kraftwerk's Avatar
Yeah.. 4 wow. If you remove the tranny mounts and engine mounts & remove the tranny brace entirely ...jeeze, is that just four bolts ?
It would certainly make the Banana / Trialling-Arm Nut, 22mm ( &bolt) a heck of a lot easier to get at...that's an educated guess, btw. Maybe you wouldn't have to even actually lower the engine, you would just remove tranny mounts & that brace.. Hmmm... you got me thinking here..
jt
'83 SC
'96 M3
6 Bicycles
2 Sailboats
Old 01-19-2017, 08:57 PM
