ASE Master Tech - 35 yrs
larrym's Avatar
Question lower cam cover corner leak - at wit's end
i have a seemingly incurable leak at only the lower rear corner of one cover (911 orientation) - on a 3.2
the covers are brand new, and pass the "flat bench fine sandpaper" test & draw-file tests - no warps
- appears to be weeping out at the corner stud & past the nut/washer, but appearances aren't everything, eh?
- this is mostly a problem when the car sits long time & the oil tank leaks down into the engine - i actually don't notice a problem when driven frequently -
have read a dozen or more threads on this cover leak issue, and tried all the usual ideas,
- no joy
y'all have any more ideas?
p.s. - - re: silicon "reusable" gskts - are they really? - i find that mine compress - always less thick after use than original out of box
"... I am German, and if it has no logic it's meaningless."
914 & 914-6 parts FS 03-2021 www.tinyurl.com/2pmpmv8y
911 parts FS 2022 https://tinyurl.com/911-Parts-FS-LCM
Old 01-12-2017, 08:00 PM
El Duderino
tirwin's Avatar
Other than using the 'thick' valve cover gaskets that John Walker recommends and barring some other simple solution, what about the Rothsport oil inlet check valve? That would keep oil leaking from the tank to the engine. Not a cheap fix but...
Pelican carries it by the way.
I tried the same silicon ones. I have another set of the good old fashioned valve cover gaskets sitting on the shelf for the next oil change.
There are those who call me... Tim
'83 911 SC 3.0 coupe (NA)
You can't buy happiness, but you can buy car parts which is kind of the same thing.
Old 01-12-2017, 08:09 PM
Jeff NJ's Avatar
The silicon gaskets have a much lower torque spec than the paper ones. If I recall correctly, it was 45 inch/lbs. but it was in the directions that came with them. No leaks for me once I switched to silicone.
1988 930 Venetian Blue
Old 01-12-2017, 08:15 PM
Member 911 Anonymous
DRACO A5OG's Avatar
+1 the silicon has lower torque range
I use the lower value recommended and take a second pass to insure all nuts are tight to silicon manufacturer specs
Old 01-12-2017, 08:32 PM
Registered Minimalist
75 911s's Avatar
Had the same problem. I sanded my covers a second time and switched from the silicone back to cheap paper gaskets. This time I was uber careful when torquing the nuts down. That has stopped the leak there. I think when I had the silicon I over torqued and when they leaked, i went back and tried to tighten again which made them leak even more.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage
Check out my 75 and 77 911S build threads
Old 01-13-2017, 05:22 AM
larrym's Avatar
thanks all - resolved
pulled it off & replaced with a different cover, re-using the old Si gskt -
meanwhile - where does one get the " 'thick' gaskets that John Walker recommends"
- is it this? Weltmeister® 911 Valve Cover Gasket, Part #65-220965-1 ??
- or these from Pelican? http://www.pelicanparts.com/catalog/SuperCat/0826/POR_0826_BASFLT_pg3.htm#item13
- or these RG-911LATE-4 http://www.realgaskets.com/index.htm
or are all above the same product from one source ????
- see http://www.early911sregistry.org/forums/showthread.php?36002-Silicone-Valve-Cover-Gaskets-Cheaper!
some ANSWERS:
- http://rennlist.com/forums/911-forum/214179-80-911-sc-valve-cover-oil-leaks-fixed-after-3years.html
- Valve Cover Gaskets - Standard vs Silicone?
.- Leaking Silicone Exhaust Cover Gaskets .. What to do Now?
Old 01-15-2017, 09:36 PM
Straight shooter
Lapkritis's Avatar
Consider swapping to the Hargett billet covers which feature the modern gasket type? These are much more service friendly and reusable.
I would also inspect the cam tower for leaks above the gasket line. There are studs that thread entriely through the casting in places with atmosphere on one side and oil bath on the other.
Sent from my SM-T580 using Tapatalk
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.”
― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
Old 01-19-2017, 07:09 AM
T77911S's Avatar
you have over tightened the gaskets.
I just hand tighten mine and they are very very lose. if you think they are tight enough, you over tightened them.
they should NOT squeeze out past the valve cover.
your leak is probably the cam line on top of the engine,
I thought my leak was the lower stud at the corner for #4. it was the cam line. there are 3 washers on there. replace them.
the reusable gaskets are awesome.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 01-19-2017, 09:46 AM
