dooop's Avatar
Question Rebuilt pre-68 tailights
Hello the whole board !
My first question on this forum will be :
Have someone already rebuilt a 65-68 tailight ?
Il yes, how to separate the lens from the bloc without breaking it !
and how to re-assemble it again, does the seal exists ?
Thank you
dooop
Old 01-20-2003, 05:57 AM
Nobody
bob tilton's Avatar
i don't know if that seal exists. i thought i could re-use the original but no - it was over 30 years old. instead i used a clear silicone which has worked well - no visible moisture on the inside of the lens. took the time to mask a bead along the edge and spread the silicone with a credit card.
considering the lens are tab-melted i don't think there is any way to remove them without breaking them. i had a new set to install so i didn't care. the lens recently became available for the SWB 65-68 cars and should be about $55 ea for the fronts. you have to melt the new tabs to hold them into the assemblies. i used a soldering gun. very easy. somewhat cheap. looks so much better than faded lenses.
good luck,
bob
68L
Bob Tilton
www.werkcrew.com
Old 01-20-2003, 08:00 AM
dooop - i have refurbished a few sets of F&R '65-'68 lights & used the technique Bob described above (clear silicone in lieu of lens seal & using a soldering iron to melt the lens tabs at the rear). In addition, replacement hollow copper rivets were supplied which also locate the lenses via the holes at either end which take the screws to attach the units to the car. The replacement lenses are available from several outlets in Germany & Holland - email me directly if you want their contact details.
Andy Boyle (UK)
'69 911E-------------->R
Andy
M&W 904 ... now gone
GT-style 356C ... also gone
Old 01-20-2003, 11:55 AM
I have a pair of early tail light assemblies in excellent unrestored original condition. Please send me an e-mail if you're interested. I'm on the road on business right now, but will be back in the office on Wednesday.
Rich
2004 GT-3
1969 911E
1988 944 Turbo
1990 BMW 325i
2001 BMW Z3
Old 01-20-2003, 10:13 PM
