JTO JTO is offline
First Valve Adjustment After Rebuild-Problems
Hi All,
I am having a local, well regarded Porsche mechanic perform the first valve adjustment on my 911S after a total powertrain rebuild. He called me to say that the rocker shafts/rockers were not installed properly and needed to be moved so that the "stress groove" or something is inside the rocker housing. He said If we don't do this this, a crack in the housing can result. Other than this, he says the car runs great and is very powerful.
Please comment on this
Thanks,
Troy
Troy
Past: 1975 911S Silver Anniversary-rebuilt and sublime.
Past: 1988 Carrera-backdated with a 3.6 and all the goodies.
Present: 2011 GMC 2500HD with the 6.0 & 4x4!, 2004 Toyota Sequoia (wife's)
Old 01-15-2003, 10:32 AM
rocker shaftposition is often overlooked. it's good that he caught it. sounds like he's on the ball.
206 637 4071
Old 01-15-2003, 10:48 AM
JTO JTO is offline
Thanks John. I was hoping you would respond. He is estimating about 1.5 hours to check and correct the shafts. Is that reasonable?
Thanks again,
Troy
Troy
Old 01-15-2003, 10:50 AM
Super Moderator
cstreit's Avatar
That's quite reasonable... It would take me 3-4 times as long
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 01-15-2003, 10:55 AM
Somatic Negative Optimist
Gunter's Avatar
Cool
Did your mechanic say that ALL shafts are incorrect? By how much? Did he notice some oil leaks from the shafts? It is true that the rocker shafts have a certain position in the casing. Aside from stress, there is the issue of possible oil leaks from the shafts. If all the rocker shafts have the wrong position, then the person who did the rebuild made a mistake. For the re-positioning of the shafts, the engine would need to come out, the shafts properly positioned and re-torqued. This would be a good time to find out if the rebuild included a set of rocker shaft seals (Two per shaft) I would get in touch with the rebuilder and put this issue to him.
I just noticed that your mechanic estimates about 11/2 hours. That seems reasonable but I also try to picture how he could do this with the engine in place. It is pretty akward to reach in there with two Allen wrenches and then use a torque wrench. Are we talking about a partial drop here? Can this be done right in 11/2 hours?
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 01-15-2003, 11:01 AM
JTO JTO is offline
Gunter,
Walt (the mechanic) says that as he is doing the valve adjustment and a piston is at TDC, he can loosen and adjust the shaft position. He said it is difficult in the car but it can be done.
Comments?
Thanks,
Troy
Troy
Old 01-15-2003, 11:14 AM
Not Quite Banned
Thomas Owen's Avatar
You most certainly can do it the car, and 1.5 hours seems fair. Get the cylinder at TDC and the shaft can be loosened and moved. I would highly recommend you talk to the builder (unless that happens to be you!) because this is an important part of valve train reassembly and should not have been left this way. You don't want it to be an indication of the attention spent on other parts of the build.
Good luck,
Thomas Owen
1972 911T
1972 911S
Old 01-15-2003, 11:22 AM
