Tensioner upgrade help!
In the middle of upgrading my 79sc tensioners to oil pressure fed. During the switch when I removed one of the old tensioners the idler sprocket arm moved. When the idler sprocket arm moved the chain did not appear to move and it did not come off of either of the sprockets. My question is am I going to have to reset the cams or should everthing be ok. Anything else I should be looking out for during the upgrade, I've read the tech article and it has helped alot.
Thanks Kevin
Kevin 79sc - Timing is everything. |
if the cams or the engine didn't turn, no problem. the idler tensions the loose side of the chain. the other side remains reasonably tight. if the engine is on TDC #1 when the tensioners are removed, the cams will stay there, unless you try to turn them, or do so by mistake. it never hurts to rotate the engine by hand a few times when you're done to be sure there's no valve to piston contact. it's also nice to check the cam timing in the end, if you have the equipment.
https://www.instagram.com/johnwalker8704 8009 103rd pl ne Marysville Wa 98270 206 637 4071 Last edited by john walker's workshop; 01-15-2003 at 07:37 PM.. |
Thanks for the help. Have one more question, when I submerged the tensioners and primed only one became rock hard. The one that I could still pump was very hard to squeeze, however I still could, does this mean it's a bad tensioner?
Thanks Kevin
Senior Member
That question is a can of worms, I think. I'd guess that Wayne would like folks to quit over-evaluating tensioners prior to installation, and I agree. Yes, there is such a thing as a bad tensioner, but I think that's rare these days. At any rate, I don't think I even bench bled mine. I just put 'em in and they've worked fine ever since.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
Author of "101 Projects"
Agreed, I've had good tensioners act this way. You might want to double-check your timing just to make sure, in reference to the chain...
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Steve Wilwerding 1998 3.4L Zenith Blue Boxster 2009 Meteor Gray Cayenne |
