BBS wheel straightening
Just bought a couple of BBS outer wheel halves and installed on lathe to check trueness.. One is not. .Can anyone tell me if it can be straighten...If so who does it ....
If changing out outers do I need new seals ---and or bolts. If so where can I buy? Can these be refinished ....Al Reed ? or Thanks TOT
TOT |
likes to left foot brake.
I would replace old seals and hardware.
If its the BBS RS wheel you can get parts here. BBS WHEEL PARTS If it is a bent RS shell you can get new shells from Mirage. Mirage Intl - Porsche Repair San Diego Did you call BBS? They sell hardware and even new BBS stickers for BBS racing rims.
It's a 914 ...
New BBS rim halves are like $150-200 each, used ones somewhat less. It might cost you that much to have your bent one fixed. I have a good wheel guy local to me, so I would take anything questionable to him for an opinion. If you have someone local, you could try that. As for refinishing, if it's just the rim half, just take it to a polisher. If you want the centers done, any good refinisher can do it. I think rgofast (not sure of the name) here on the forum may refinish BBS wheels.
Check w wheel collision center in Bethelehm/nazareth ? Pa , they do a lot of german car stuff.
I am quite sure they can straighten and repair almost anything but yes, you are talking hundred and 50 to 200 if it's not really out of whack. They take several wheel (TIR) readings/measurements before and the same after
1979 SC 1986 Carrera 3.6 L+ |
wheel info
Thanks for info
TOT |
